stupid errant wire question
Old Oct 5, 2007 | 12:45 PM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
Default stupid errant wire question
Hey all. I've got this wire from under the dash hanging over the clutch pedal on this '75; black with a female spade connector. Getting home from work the other morning I apparently grounded it to the clutch pedal with my foot (seems there's more length to it than I thought) and I got a buzzing. Freaked me out! So, got into the garage, clutched again and buzzed again. Also did it after I shut off the engine.
We've all got a list of what's gotta be done NOW! and what'll wait. They're usually several pages long. I know mine is.
So.... I'll have to pull the dash over the column sometime soon for work on the headlight switch. It'll be a good time to track this wire. But, it would be nice to know just what is buzzing, why is it buzzing, where is it buzzing from?
Old Oct 5, 2007 | 01:45 PM
GD70's Avatar
GD70
Is it possible it's the key warning buzzer? Just a thought.
If you have the chassis repair manual for your year check the wiring diagrams.
Old Oct 5, 2007 | 04:29 PM
Overlord's Avatar
Overlord
Don't have that. Should become clear on the weekend tho. Might even be a leftover from these autometer gauges.
Old Oct 5, 2007 | 07:00 PM
Duke94's Avatar
Duke94
Does it look like a GM spade connector or a hardware store crimp on? If it's crimp on, then it didn't come with the car and is probably from a PO install of something. Usually any GM connector that could short something out if it touched ground has a hard shell case around it.
To stupid errant wire question
