Thinking about doing an off frame restoration
Old Oct 8, 2007 | 01:31 PM
JoeRags's Avatar
JoeRags
Pops bought our car when I was 15.
10 years and probably $50k+, we've got a killer driver. Its a HUGE undertaking to do a frame off.... You'll find something around every corner you'll want to fix or correct.
I must say, the time spent with him working on it is priceless.
Old Oct 8, 2007 | 01:34 PM
corvetteload's Avatar
corvetteload
Buy the gun now and save yourself a lot of trouble!!!!!!
Old Oct 8, 2007 | 01:50 PM
randyward's Avatar
randyward
Lot's of good comments here and I'll add mine. I did my frame off in about 3 months (didn't need any body work, just chassis rebuild) It's straightforward to remove the body, but as some said, in all probability you'll end up cutting some bolts. When you get there, we all have our best methods.
My underside is better than new and once it's apart it's a lot of fun to put back together. All new and clean. I even blasted it in my front yard (most of the grass has grown back).
Go for it and do the lift outside. I only had 9 feet and did it in the garage but used 2 engine hoists and that worked OK.
Regards,
Randy
Old Oct 8, 2007 | 04:55 PM
bj1k's Avatar
bj1k
Originally Posted by cgc
Thanks to all!
I have read all your replies with great interest. Easy Mike your statement that your intent is not to discourage me, only to ensure me that I understand the size and scope of the project was very much welcomed. Yours and the other's comments is what I was wanting. bjlk your offer to be there as well as many others to help guide me through are very encouraging.
I am sure I can do the work its the fear of the unknown. I have never tackled such a big project that could have such disastrous results. To take such a good car that is basically sound and pleasing to the eye and maybe have the front clip break off scares me. Is this a much bigger endeavor than I am allowing myself to believe because I want to do it.
I have been working on (on and off) cars everysince my Uncle started me out on Model A's when I was 14. I did most of the work putting my 68 back together. I was 20 years younger hope I have gotten smarter will let the Grandson get his hands dirty.
I have a 2 1/2 car garage with a 8' celing. If I do build a hoisting device is this high enough? I will have to clean out some of my wood working tools. I have a good selection of hand tools, a buzz box welder, and a friend has a wire welder. No oxy-acetelene torch. Since I don't have an easy way of hoisting the body is it a bad idea to lift by hand(s)?
RSTR90 you asked where is Grayville, Il? In Southeastern Il. on the Il. In. border. The last town on I-64 going East. About 45 mins. from Evansville, In. I have been to you city a few times. It takes me about 3 to 3 1/2 hours to make the drive but I drive slow just ask anybody. Are there any Fourm members from around this area? I may need to buy a hoisting device and body dolly.
What frame off reference book should I buy? Is there a Fourm Thread on removing the body I should read? Does one of the members have a site I need to visit? Is the rusty body bolts my biggest challenge?
The decision has not been made yet but I am heavily leaning toward removing the body. I will try and get you guys some pictures of my car as it is now. The car will be my Grandson's.
You asked if it's a bad idea to lift the body by hand. I wouldn't recommend it unless you have a bunch of brawny buddies with a lot of patience and have a lot of on hand to keep them in a good mood because it's a slow process. You will start lifting and discover that there is still something fastened and will have to set it back down. With a hoist, you can just take your time.
Old Oct 9, 2007 | 10:39 AM
cgc's Avatar
cgc
You guys are wonderful. I had about 20 replies some
with offers of informational help. I will be drawing on
that well because I (and the wife) have decided to
remove the body from the frame. I am not sure just
when I decided but I started cleaning out my garage
yesterday. Not sure just when I will start on the car.
I have to order some books and do some reading and
research, build a dolly and with winter coming on (it
gets real cool here in southern Il. and all I have for
heat in the garage is a barrell wood burner). Before
I start we will have to take the old vette out for a drive.
Does anyone know of a Corvette shop around Evansville
IN. I used to drive to Carbondale, Il to a shop and buy
parts but think they are no longer in business.
Again thanks to all of you.
Charlie
Old Oct 9, 2007 | 07:15 PM
76 VETTE's Avatar
76 VETTE
Did My 76 By Jacking Body Off Frame By Myself. Not Too Bad Of A Job. Must Have Crawled Under And Out 1000 Times But It Can Be Done
Old Oct 9, 2007 | 09:07 PM
dannyman's Avatar
dannyman
Yeah, you may as well do a body-off! A winter project in Illinois is a great idea. I would caution you not to set a time limit. May end up taking two or three winters.
