1970 Windshield door fit problem.
Old Oct 7, 2007 | 05:06 PM
RABVET427's Avatar
RABVET427
Default 1970 Windshield door fit problem.
My windshield wiper door on my 1970 does not fit flush on the passenger side whereas the drivers side seems fine. I would estimate that it's sticking up just under a 3/16 of an inch and by simply applying a little pressure it goes back down nice and flush only to pop back up again. --- How do I go about correcting that mismatch on the left side?
Thank you
Old Oct 7, 2007 | 07:55 PM
72GACRZR's Avatar
72GACRZR
You might have to take it completely off and check the mounting structure underneath. If it is bent or if something is out of adjustment, I think that may be the only way to see it. Sounds like a possible adjustment, since you can manually push it down. The bolts have a tendency to be brittle and you need to use care and order a new set to replace them when you put it back. When I first got my car (72 vert) the vacumn didn't work, so I took the entire wiper mechanism out and cleaned it up and repainted it, replaced the hoses and all the other rubber parts. When you say left side are you referring to drivers side? The wiper arms set on a switch on the passenger side that may be mounted too high.
Old Oct 8, 2007 | 08:36 AM
jnb5101's Avatar
jnb5101
as 72 said, check the plunger on the right side that hits the wiper safety switch. ther's an adjusting bolt that may have moved. that could be springing back and causing your problem.
jeff
Old Oct 8, 2007 | 10:26 AM
Red70vette's Avatar
Red70vette
Keep the ideas coming I have a 70 with the exact same problem. I removed the door and remounted it and didn't see much room for adjustment although I didn't look too hard as that was not my major concern at the time.
Old Oct 8, 2007 | 10:49 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Another thing is if the car has replacement wiper blades on it. The factory blades were low profile compared to todays replacements. The door may be hitting on the wiper blades. Just another idea to check.
To 1970 Windshield door fit problem.
