adding seat foam
Old Oct 11, 2007 | 10:53 AM
dholifield's Avatar
dholifield
Default adding seat foam
The foam in my 72 is rather caved in on the seat bottoms. is it possible to remove the seats and add new foam in the bottoms without taking the seat covers off? thanks...don
Old Oct 11, 2007 | 10:54 AM
Durango_Boy's Avatar
Durango_Boy
If you think about all the springs and webbing to remove that would be a lot harder than taking the covers off.
Old Oct 11, 2007 | 11:05 AM
bashcraft's Avatar
bashcraft
You can't replace the foam without taking the covers off.
Old Oct 11, 2007 | 11:13 AM
dholifield's Avatar
dholifield
thanks guys. just was looking for a shortcut. guess short of removing the seat covers i'll just have to sit on a block of foam. don
Old Oct 11, 2007 | 11:15 AM
dholifield's Avatar
dholifield
after reading the original post i think i left some info out. what i want to do is add a new thin piece to whats already in there. try to build up whats in it now without removing the cover.
Old Oct 11, 2007 | 11:59 AM
tigers123's Avatar
tigers123
Replace the foam completely if you are going to keep the car. The replacement foam from the corvette catalogs is really comfotable and you will be glad you did. I had mine done with covers and foam from a catalog and installed by a professional upholsterer. Money well spent. You have to use a few special tools other than the hog ring pliers to do this right. On my 1974 there are wires that run through the cover and you need a special tool which comes in the installation kit to do this. It pulls the wire through the foam. It takes some patience and knack to do this right. Plus he heated the cover up with a heat gun to move it where it needed to be and get rid of wrinkles. I understand now how to do it, but if I ever need it done again I will go back to him, as he does extremely nice work.
Old Oct 11, 2007 | 01:02 PM
1971Coupe's Avatar
1971Coupe
NO, because the foam is attached to the covers with clips and you are going to need an installation kit too. You are going to be recking a few hog rings and clips in the process....maybe just buy the foam bottoms and kit, or just get a seat cushion for ontop of your seats...no easy way around it.
Old Oct 11, 2007 | 05:38 PM
Alan 71's Avatar
Alan 71
The bottom seat cover is a lot easier to get off and back on than the cover for the seat back. If you're careful it's a pretty straight forward job. Do them 1 at a time so you have a complete one to refer to as you put it back together.
Regards,
Alan
On my 71 the foam that's part of the seat cover itself was what had deteriorated. It had become the consistency of sawdust. That's what was making the cover loose. Needed new covers. (Al Knock)
To adding seat foam
