loud clicking / tapping sound ??
Old Oct 16, 2007 | 10:39 AM
Scottys78's Avatar
Scottys78
Default loud clicking / tapping sound ??
Something went wrong in my engine. I started up my Vette and now there is a loud clicking / tapping sound. I don’t think it’s a valve tap. I think the sound is coming from the distributor? I took off the distributor and made sure nothing was loose, but when I put my hand on top of the distributor I can feel the clicking. What do you guy’s thing the tapping noise could be.
Old Oct 16, 2007 | 11:34 AM
Young69Owner's Avatar
Young69Owner
Have you done anything to the car since it was not making noises? Is it any harder to start the car?
Old Oct 16, 2007 | 11:35 AM
Young69Owner
BTW -- when I lived in Wayne, I dated a girl that lived in Narberth.
Old Oct 16, 2007 | 12:53 PM
Scottys78's Avatar
Scottys78
No I haven’t done anything and no the car didn’t have any trouble starting
Old Oct 16, 2007 | 12:54 PM
Scottys78's Avatar
Scottys78
Narberth is a good town to live in.
Does she still live in Narberth?
Old Oct 16, 2007 | 01:15 PM
rihwoods's Avatar
rihwoods
I'd listen to your valve covers with a long wood dowel or screw driver to your ear...it could be a broken valve spring.....anyway,you can probe your engine that way to isolate /locate origin of noise...
Rich
Old Oct 16, 2007 | 01:31 PM
John Ulrich's Avatar
John Ulrich
I had one of those AIR check valve coming of the exhaust manifold recirculation system, rot off on the bottom so you did not see it. I thought I was dropping a few lifters until I stumbled on to the culprit. I fixed it with some JB Weld over 10 years ago and it holding fine.
JU
Old Oct 16, 2007 | 02:35 PM
Durango_Boy's Avatar
Durango_Boy
Make sure the distributor has vacuum. Also, pull the cap again and check for any loose screws or broken springs.
Old Oct 17, 2007 | 01:47 PM
Scottys78's Avatar
Scottys78
Rich
I’m not sure how to go about doing that
JU
It’s not that
This I did…one of the spring loaded screw things was loose and I tightened it, but the noise continues
Old Oct 17, 2007 | 02:00 PM
OregonVette80's Avatar
OregonVette80
Yep....
Check the archives maybe, because I had the (potentially) same thing last spring.
Turned out it was a header gasket crack on the rear of the engine (closest to the distributor). So it sounded like a clacking/tapping/slap sound at the rear of the engine.
New header gasket....wala!
Old Oct 17, 2007 | 03:42 PM
Scottys78's Avatar
Scottys78
Originally Posted by OregonVette80
Yep....
I replaced my header gaskets less than a year ago when I added the side pipes
Old Oct 17, 2007 | 08:01 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Use the wood dowel or a piece of heater hose to listen through. Listen to the FUEL PUMP. Mine started clacking and it was the pump rod. I replaced it....quiet again.
Good luck ..
Old Oct 17, 2007 | 08:05 PM
ksbunting's Avatar
ksbunting
Had the same exact noise and the guy who built my engine put his hand on the distributor and it went away.
Turned out the distributor drive gear was moving up and down inside the engine because I did n't have the end gear shimmed properly.
Took it out and had it fixed in under an hour and back in and noise was gone.
Old Oct 18, 2007 | 02:29 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I blow header gaskets almost everytime I really get on it. Tried 3 or 4 different types. Could be a header gasket even though you replaced it a year ago. They sound like a metallic clicking sound almost like valvetrain noise.
Old Oct 18, 2007 | 11:03 AM
Scottys78's Avatar
Scottys78
So far I have tried all that I can think of…
Some how I can’t figure it out, I need someone who knows better than me to listen to it.
I don’t want to have to take it to a shop but this one is over my head.
I’ve been planning a crate motor for my baby and this could be the push I needed. I don’t want to spend money to fix this, to than buying a crate motor.
Do you guys think I should try driving the car a little and see want happens to the noise?
Old Oct 18, 2007 | 11:32 AM
Durango_Boy
Well there is a crate motor in your car's future so a catastrophe from driving would be easier to take and like you said might push you to get your crate motor faster.
Old Oct 18, 2007 | 03:42 PM
hugie82's Avatar
hugie82
If you have the space and some tools at least pull the valve covers and check for a lose rocker or broken spring. If you need to drive it to a place for mech. work as long as you have oil pressure I would chance it.
To loud clicking / tapping sound ??
Old Oct 18, 2007 | 04:12 PM
63mako's Avatar
63mako
Did you check for a blown header gasket??
Old Oct 18, 2007 | 04:14 PM
rihwoods's Avatar
rihwoods
With engine at idle, listen to each valve cover by contacting wood dowel inline with spark plugs below...if nothing there, listen to fuel pump as suggested...(block wheels)..you can also probe around engine block..just be careful around waterpump/fan belts,etc...
I found a broken valve spring doing this on my 78...
Old Oct 19, 2007 | 09:56 AM
Scottys78's Avatar
Scottys78
last night I tried listening to the valve covers I can’t be certain where the noise is coming from. All I can be certain about is the noise is coming from the rear of the engine.
I’m going to take the valve covers off tonight...
