No blinkers
Old Oct 17, 2007 | 02:12 AM
wiseman79's Avatar
wiseman79
Default No blinkers
Blinkers quit working recently. Not only the flashers but dash indicators, can't hear the flasher ticking, like they are completely disconnectd. The body shop was in my dash recently, but not positive if it coincided with that for sure since I may not have noticed right away. Is there something simple they could have knocked loose or diconnected? Something else to check? Thanks as usual.
Old Oct 17, 2007 | 02:23 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Blown fuse? Bad flasher? Steering column harmonica connector partially disconnected?
Old Oct 17, 2007 | 07:18 AM
Durango_Boy's Avatar
Durango_Boy
The signal flasher is clipped behind the passenger knee pad. The hazard flasher is in the fuse panel under the driver's side dash. Replace both with new flashers just to be safe.
Old Oct 17, 2007 | 08:06 AM
Green73's Avatar
Green73
I'd look at the signal switch and the harmonica connector. Connector is under the dash where the steering column ends. Your toes point at it when your foot is on the brake. If the connection looks good, you can try a test light on the different leads. Changing out the switch is a PITA. Good luck.
To No blinkers
