68 brake problem
Old Oct 22, 2007 | 03:43 PM
cgc's Avatar
cgc
Default 68 brake problem
I first posted this on the Tec and Perf. forum then tryed to move it here because I think it was on the wrong forum. Unable to move it so I am reposting it here with some changes. -- Both front brakes locked up after a hour drive through three small towns. I normally have a very "soft" brake pedel. I noticed the pedel was getting harder and harder. About 6 miles out of town I could smell the pads getting hot. Stoped and the pads were "smokeing" hot. Pushing on the pedel was like pushing on a large rock. It would not move. Rear were ok. When I tryed to move the car the rear wheels would spin. I seperated the MC from the power booster about 1/4" and the pedel could go to the floor . But when I put the MC back on the front breakes were still locked up. Unbolted the MC all the way and just started the nuts on the booster just to hold MC in place. This time the brakes released and drove home (slowly and carefully). At home I reseated the MC 100% with the booster and the brakes are working fine. Would appreciate your thoughts.
Old Oct 22, 2007 | 03:55 PM
RHD '68 L89's Avatar
RHD '68 L89
Replace the front rubber hoses. they swell internally and lock up the brakes. Had it happen to me once.
Old Oct 22, 2007 | 04:32 PM
bj1k's Avatar
bj1k
Default Don't overlook brake hoses.
Had a car once that seemed like the caliper was locking up and not releasing. Went through several calipers until I realized it had to be a bad hose. The hose looked perfect on the outside but had a piece of the lining break lose on the inside and hanging down worked like a one way valve. It would let the brake fluid in to lock the brakes but wouldn't let the brake fluid return when you let your foot off of the brake, causing the brake to lock and wear out pads on that caliper. Put a new hose on it and never had a problem since.
Old Oct 22, 2007 | 04:33 PM
Durango_Boy's Avatar
Durango_Boy
Check those first. They will look fine from the outside but the inside may be a different story. They swell, locking the fluid int he calipers.
Get some good S/S braided one and replace all four.
They may not be your real problem but if they have never been replaced it's a good preventative maintenance.
Old Oct 22, 2007 | 09:29 PM
ksbunting's Avatar
ksbunting
I just had the same problem on my daily driver (not a Corvette)
I could smell the pads burning and feel the wheels dragging.
So I replaced the calipers, problem still was there. I replaced the rubber hoses, problem cured instantly. I didn't need the calipers. I have heard of this brake hose problem over the years about hoses looking good on outside but swelled shut on the inside sort of like hardening of the arteries in your body, but now I have experienced it.
Replacing the hoses is a quick and cheap remedy.
Kurt
To 68 brake problem
