Vacuum Gauge
Old Oct 24, 2007 | 10:04 PM
wagonerjim's Avatar
wagonerjim
Default Vacuum Gauge
I want to check some of my vacuum lines for leaks and to see if they are holding the right amount of vacuum.
What do all of you use to check the vacuum lines on your car?
I found one at Steve's Wholesale Tools for $19 and it says its a Vacuum Gauge and Fuel Pump Tester. Is this what you check for vacuum leaks and pressure?
Please tell me what to use. :
Old Oct 25, 2007 | 01:54 PM
Jay-Dog's Avatar
Jay-Dog
That'll work fine. Alternately, you can by a guage that also comes with a pump. It costs a little more but can be used for brake bleeding as well as pressurizing vacuum controls for diagnostic testing. I've seen the same $19 guage at Harbour Freight for $19 and Napa for $49. I'm sure somebody will chime in with the Snapon tool quality issue but for occassional home use, go the cheap route. BTW, I have Snap on, Craftsman, and China crap elcheapo tools depending on purpose.
Old Oct 25, 2007 | 05:30 PM
wagonerjim's Avatar
wagonerjim
Thank you for the advice.
Old Oct 25, 2007 | 08:08 PM
78Vette-SA's Avatar
78Vette-SA
If I even think there is a leak somewhere besides listening for it (sometimes difficult) I'm pretty liberal with a can of starter fluid. If there is a leak it gets sucked in and the engine will race for a second. Won't hurt anything and dries instantly.
If headlights and wipers (if vacuum operated) are working properly and engine is running normally and idling good, you probably don't have a problem but certainly testing it can't hurt.
My .02.
Old Oct 26, 2007 | 01:50 PM
C3 4ME's Avatar
C3 4ME
I bought mine a Sears, just the other month. I want to say it was $20 to $30, but can't remember exactly how much.
Old Oct 26, 2007 | 02:50 PM
Bob Onit's Avatar
Bob Onit
Pump is very handy for Corvette systems
Got an AutoZone in your area?
Rent their vacuum pump that has the gauge on it.
Give them $50, use the pump/gauge to test, bring it back and get your $50 back
To Vacuum Gauge
