Who will be the first?
Old Nov 4, 2007 | 10:44 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Default Who will be the first?
...to install one of these in a C3?
According to the article, only two ZL-1 equipped vettes were built as standard equipment (in 1969). It looks like it would be a challenging project, but ultra- .
Old Nov 4, 2007 | 11:28 AM
Steve439's Avatar
Steve439
IIRC those blocks have provision for a
mechanical fuel pump and a clutch z-bar.
This version has a carb so no F.I. mods needed.
It should bolt in over a weekend (three if I did it :o )...
Old Nov 4, 2007 | 11:49 AM
Jim_Harrison's Avatar
Jim_Harrison
I don't get it? The original block was made from aluminum to save 100 lbs. This one is cast iron?? What's the point???
Old Nov 4, 2007 | 11:52 AM
another-user's Avatar
another-user
theres 2 engines, the reproduction ZL-1 in all aluminum, and a ZZ427 with a cast iron block.
Old Nov 4, 2007 | 01:44 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Two were built for sale. There were several engines shipped from Tonawanda to St. Louis with Corvette stampings, and it seems likely that GM built a few cars for internal testing and publicity purposes.
Old Nov 4, 2007 | 01:50 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
They should build a ZZ427 small block they would not be able to keep them in stock
Old Nov 4, 2007 | 02:02 PM
Ironcross's Avatar
Ironcross
Nothing but a high priced incorrect copy. A stock L72 will blow it in the weeds with this new ZL1`s 10-1 compression. The outside looks good but it`s the internals that produce the HP. ...
Old Nov 4, 2007 | 02:49 PM
Durango_Boy's Avatar
Durango_Boy
I agree, a 7.0L ZZ motor would frig'n ROCK !!!
Old Nov 4, 2007 | 03:39 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
According to the first line of the article, the non-limited edition iron-block version is the ZZ427.
Old Nov 4, 2007 | 03:56 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
Old Nov 4, 2007 | 04:01 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Unless you only do straightline stuff, or got a helluva big wing on your machine, all the horsepower in the world won't get you around a corner quickly (these are sportscars, after all). I'm presently building a ZL1 block based aluminum engine. I know I won't have more horsepower than everybody else on the track/course, but I'll be in the ballpark, and I'll certainly have less frontend weight than a good share of the machines there.
Old Nov 4, 2007 | 04:44 PM
SteveG75's Avatar
SteveG75
I'd rather buy one of these from Shafiroff. 427 vs 540.
Don't forget the 2 yr/unlimited mileage warranty as well.
Old Nov 4, 2007 | 04:46 PM
billla's Avatar
billla
St. Jude Donor '14
It's that old debate - is "old school" cool when it gets it's a$$ kicked by "new school"? I'm right in the middle of that debate myself...I always wanted a "correct" LT-1...but when I look strictly from a performance perspective a hopped-up LS-series makes a lot more sense.
It took a while, but I think the break between "classic" and "fast" has happened over the last few years with the return of performance engines like the LS series. We used to have to stick to the old stuff because the new stuff was junk (305, etc.). No longer true.
BTW, the ZL-1 block has been available for a while...P/N 12370850 - $4,689.95 at SDPC.
Old Nov 4, 2007 | 06:25 PM
Ironcross's Avatar
Ironcross
Thats exactly my point. They have all the correct stuff on the shelves and to try to make a limited edition and give you a certificate of authenticity of what. It`s not the real thing, it`s a phony called ZL1. It`s not even in the same ballpark except for weight. All your getting is expensive documented papers. Big deal. You can make your own the way you want for less money and more HP. So what do you really get? A low HP certified 427. It certinally shouldn`t make any Vette more valuable. It`s just a numbered new crate engine.....not even a good copy.
Old Nov 4, 2007 | 07:52 PM
dgruenke's Avatar
dgruenke
They shouldn't even be able to put the ZL-1 tag on it if it doesn't have the aluminum block. Without that, it is just another 427.
Old Nov 4, 2007 | 08:48 PM
69427's Avatar
69427
This looks to be a very reasonable price for that sort of straightline performance potential, but you have to keep in mind there's still 260# of cast iron in that block.
Old Nov 4, 2007 | 09:13 PM
billla's Avatar
billla
St. Jude Donor '14
Do. Or Do Not. There is no "try".
- Yoda
To Who will be the first?
Old Nov 4, 2007 | 09:26 PM
69427's Avatar
69427
You are correct. Unfortunately, there appears to be a few members who aren't reading your post.
Old Nov 4, 2007 | 09:47 PM
FRSTR90's Avatar
FRSTR90
I would be more likely to put one of these in my vette since it is a SB bigger than what was available. No way would I put a BB427 in what could have been a 73 BB454 vette.
The only thing I think this engine is good for is for the people that have a car from 1966-1969. If my car could have come with a BB454, there is no way I am going to put a BB 396-427. It it could have came with a 454, then it will atleast get a 454 (or maybe more )
Personally, I think this engine is a joke. GM is using history to make them a few bucks. I am sure there will be a number of disappointed people when they find out this engine isn't even close to the legendary 427. For those who don't know any better, they are going to think that 1960's racing is a joke when a brand new Z06 hands them a new one.
Old Nov 5, 2007 | 08:52 PM
SteveG75's Avatar
SteveG75
How about:
World Products 108053A
540 cubic inches, 630HP, 630 Ft. Lbs., Merlin X Aluminum block, Merlin III 350 Aluminum heads, $16,000 from Summit Racing and you still get a 2 year warranty.
