LED tail lights
Old Nov 25, 2007 | 04:08 PM
TPI BOY's Avatar
TPI BOY
Originally Posted by vettehed
Bought these at Harbor Freight Tools for 12.99 each. They are trailer lights. They fit perfect in the holes and have black rubber bezel around them. I did have to cut out the inner hole because the back of the unit was square where the old light housing was a different shape. Then I spliced into the harness to make both outer lights work for tail lights, brakes, and blinkers.
Do you have a part#
Old Nov 25, 2007 | 04:20 PM
EyeLuvCorvettes's Avatar
EyeLuvCorvettes
http://www.harborfreight.com/cpi/cta...emnumber=93263
ITEM 93263-5VGA
on sale!
Old Nov 25, 2007 | 04:28 PM
TPI BOY's Avatar
TPI BOY
Do you have to get a different blinker
flasher
Old Nov 25, 2007 | 08:33 PM
jsrajca's Avatar
jsrajca
Those lights are just great and your vette looks awesome. i agree
more pic. of your car? Newbie Johnny R-75
Old Nov 26, 2007 | 03:02 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
flasher
You'll need a different flasher. Any parts store should have a two-prong heavy-duty electronic flasher that will be a direct replacement for the mechanical original.
Old Nov 26, 2007 | 04:10 AM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
Will you take some pictures in the evening or at nite??
Old Nov 26, 2007 | 09:01 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
well the wife saw the red car above and loved the tail lights and said she is ordering me a set so i guess its final on what i am getting.
Old Nov 26, 2007 | 10:01 PM
lvrpool32's Avatar
lvrpool32
Originally Posted by EyeLuvCorvettes
I saw the same lights in Autozone this afternoon...they wanted $32 each!!
Old Nov 27, 2007 | 05:50 PM
starbai's Avatar
starbai
it looks the same size but i may as well ask---
will this fit in the rear bumper of an 81?? lol
Old Nov 27, 2007 | 06:15 PM
neuroclast's Avatar
neuroclast
That looks pretty sweet TPI! That's pretty much what I'm going to do, just with more LEDs and keep the reverse lights. I like those though, nice looking.
Old Nov 28, 2007 | 02:55 AM
fauxrs2's Avatar
fauxrs2
How about a p/n - nevermind - found them
Old Nov 28, 2007 | 11:58 PM
vettehed's Avatar
vettehed
I will post some pictures of what they look like in the dark.
I believe the lights from harbor freight were for 4" holes...you can try to measure the hole in your bumper. The rubber grommet provides a little flexibility for non-exact fitment. Most cities have a HF or other store that sells these. Go buy one and see if it fits in the hole. If not, take it back.
I did not change out the flasher or anything else and it works fine.
The led lights come on faster, are brighter, and are supposed to last longer. An incandescent bulb has to wait for the element to heat up to the point that it glows. There is a noticable difference in the "come on" time.
Old Nov 29, 2007 | 09:09 AM
  #33
442olds's Avatar
442olds
I went one step further with the trailer lights. I mounted them in the steel cup and then welded on nuts to the steel cup so that i could reattach the stock taillight lens. I'll have to dig up the pictures of the lights on in the dark.....their at home somewhere.
unfortunately, I had to pay full price for them as Harbor Frieght wasn't selling the led trailer kits at the time.
Old Nov 29, 2007 | 02:05 PM
  #34
wcsinx's Avatar
wcsinx
You are my hero!
I'm stopping at Harbor Freight on my way home.
LEDs are so much better than filament bulbs for this application. Much faster cycle time, longer life, better visibility, vibration resistant, etc.
Old Nov 29, 2007 | 02:15 PM
  #35
TPI BOY's Avatar
TPI BOY
Originally Posted by LIQUIDDRAGON
that is frikkin sweet. i like the way it look. can you post more pictures of the car?
How did you mount them in the holes so they don't fall out
Old Nov 30, 2007 | 07:35 AM
  #36
Bruce C's Avatar
Bruce C
With LED's, you have to look at the angle at which they throw the light.
Look at the specs before you buy, a lot of the bright ones have narrow angles and will look like little spots. Look at the specs for voltage, LED's don't like over voltage and burn out really fast, if you subject them to voltages outside their specs.
My .02
Old Dec 2, 2007 | 10:09 PM
  #37
EyeLuvCorvettes
any other pictures from people?
To LED tail lights
Old Dec 2, 2007 | 11:26 PM
  #38
vettehed's Avatar
vettehed
Same pictures, but at night. These were semi-tight in the hole, but I put some contact cement on the back to hold them in. They have been in about a year and a half. I know it sounds pretty redneck, but it worked...maybe someone else can think of a better way to mount them?
Old Dec 2, 2007 | 11:30 PM
  #39
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Bright doesn't seem to be a problem.
Old Dec 3, 2007 | 12:22 AM
  #40
EyeLuvCorvettes
wow, those are bright. Thanks for those pictures
