I'm concerned that if the epoxy ever breaks off it'll end up in the cylinders.
i share your concern and will be looking down the throat often. That is why it should be tig welded. no worries.
anyone that "tests" this should plan on a tig weld if their combo like it.
there are tremendous sonic shocks that i suspect would spit out silicone in a much shorter time than epoxy. i've used jbweld inside my manifold for 5+ years. it will fail someday but is great for testing ideas.
I gotcha now.Maybe I'll try filling on both sides of screw or just filling the whole thing with out the screw and then redrilling for the screw to be accessed.But anyway I got the idea,I just got off track for a second.
watch out for carb ports! the holley power valve has a 1/8" hole and must not get blocked.
OK thanks...I plan to put in a long screw and epoxy around it and when the epoxy is almost setup I will back the screw out leaving the threaded hole-then I can drill it out for the screw head.(then blow it out of course)With the carb gasket between the manifold and the carb base this should seal up nicely around the screw head.
Another thought-If some mesh or screen was cut and put in the epoxy it might stay together if it ever cracked.
i have an edelbrock 1406 600 cfm, and the design is a little different underneath. wouldn't you lose power or wouldn't it be bad for the motor if the power steering or PCV takes an unequal amount of vacuum from both sides of the engine?
on my 61 i just epoxied over that screw. epoxy can be removed with heat, a match or a small torch will soften it. JB Weld claims it takes 600F. Easily exceeded with a match
i went thru my junk carb pile, and some leak LOTS -holley 4011 awful.
others are not too bad.
But, they all get worse with a 2 hole manifold. They appear to be designed for a stock 4 holer.
I used to blame poor mpg on the cam, now i'd say much of the loss was the 2 hole manifold! So, guys, depending on your carb, a 4 hole plate could stop about half the internal leakage, without any epoxy. Post pics of what u have.
i have an edelbrock 1406 600 cfm, and the design is a little different underneath. wouldn't you lose power or wouldn't it be bad for the motor if the power brakes or PCV takes an unequal amount of vacuum from both sides of the engine?
I don't know. this is an experiment.
This is not an ALL or NONE mod.
u could reduce the leakage to say, 1/4" or so, and still get most of the improvement, while maintaining 8cyl brakes/pcv
I'd save gas by not driving the Vette if it were really a consideration, but gas mileage has never figured into my consideration on whether to drive the Vette or not.
Gas use has zero effect on my Corvette useage and always will.
I'm just curious, why would they manufacture these passages into the carb if they just hurt performance / MPG?
why did a new then 1976 get 13 mpg? i took off the exhaust and put on duals, and it went up to 17.6. And it made more power.
so tell me why they made it the way they did?
Would this mod help that car? How could it? It had a stock 4 hole manifold. it got 17.6. That is good.
This topic is about a c3 that once got 17, was modded, and now gets 9-12. what went wrong? Sure the owner has a job and can afford it. But, he is dumping gas down the sewer for no reason.
To save gas in my Vette, I stopped driving it and took up jogging! Now my legs are much more powerful than before, and I use no gas at all. Just spring water.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
With an LM-1 wideband O2 sensor and a overdrive tranny I get over 25MPG on the highway with a 550HP small block. The only way you are going to get your motor tuned correctly is with a wideband
Can I ask a stupid question?
What does an O2 sensor do to a motor with no computer?
Do you have to have fuel injection or something?
You have me very interested...
I might believe the 25mpg with the overdrive tranny, but I don't get the O2 sensor.
No I am not joking and 25mpg @ 80mph too, engine is turning 2000RPM's
With a wideband O2 sensor you can adjust you fuel mixture correctly for idle, cruise and WOT, and get pretty much the same results as fuel injection. Without a wideband you can't tune correctly and you are probably getting crappy gas mileage
