Spark plug gapping....
Old Nov 13, 2007 | 07:20 AM
ShaneLU97's Avatar
ShaneLU97
Default Spark plug gapping....
Would like to replace my plugs in my 383 and I have all the shop manuals for my car. Even though the vette never came with a 383, can I use the same gapping as listed in the manuals?
Shane
Old Nov 13, 2007 | 07:42 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
normally yes,
but if you are runnning and an HEI ignition you can open the gap up to as much as .050 depending on the application. Though generally i would say .045 is right for most HEI applications
tim
Old Nov 13, 2007 | 08:30 AM
ShaneLU97's Avatar
ShaneLU97
Originally Posted by sweethence
normally yes,
tim
Great, thanks. I forgot about the HEI and that is a good point. Would you happen to know of a good primer on the subject?
Old Nov 13, 2007 | 09:13 AM
sweethence's Avatar
sweethence
I only know the old rules of thumbs off the top of my head, i.e when you raise compression or go to forced induction you must reduce the gap about .004 for every 50 hp. And when you add an HEI you can open the gap from .002-.005 from standard, with some aftermarket ingition companies ( mallory, DUI, etc) claiming you can open up to .055 depending on application. I run a DUI HEI unit at .040, and then read the plugs and adjust from there. It seems happy at .040 so thats where i keep it
some more expert techs please chime in
tim
Old Nov 13, 2007 | 09:40 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I run .040 in my 383 in my 61 with HEI. Seems to burn well. NGK's.
To Spark plug gapping....
