Crate Engine
Old Nov 13, 2007 | 11:54 AM
stinger12's Avatar
stinger12
Default Crate Engine
I am researching whether it is worth it to upgrade my original block to 400 horsepower or just buy a crate engine with 400 horsepower. Any recommendations for a 400 hp crate engine...and for how much? Please post links.
Old Nov 13, 2007 | 12:07 PM
Jims79's Avatar
Jims79
Your profile says you have a 76 coupe. My .02 don't waste your $$ rebuilding the L48 just buy a HP crate motor and junk,sell,store the L48 its not worth anything. (again my .02) There are many sites like Jegs.com summitracing.com pace.com or pacemotors.com and GM crate motors (not sure of the link) But there are 100's of sites to buy one of these motors and get a warranty to boot. Another thing you may want to think about is a new trans auto or manual w/an overdrive.
Old Nov 13, 2007 | 12:53 PM
stinger12's Avatar
stinger12
That's what I thought. I want to find a reasonably priced 400 hp crate engine. Any suggestions?
Old Nov 13, 2007 | 12:56 PM
dadyztoy's Avatar
dadyztoy
im in the same boat, and there are a million options when looking up crate motors, would you be better off looking local, at engine shops, or would it be cheaper online?? If so links please
Old Nov 14, 2007 | 01:08 AM
stinger12's Avatar
stinger12
bump
Old Nov 14, 2007 | 01:31 AM
koilmaker's Avatar
koilmaker
2nd Gear
Default Crate Engine Costs
Stinger12,
I really think that you should explore rebuilding the existing engine. There are many reasons for or against, but you probably have a person close to you that would probably love to help you through it.
This person most likely has done this in their youth and has lots of information and insight that they would love to share.
However, the most important aspect would have to be the cost. I have seen all your posts and it looks like you have spent several dollars and hundreds of hours perfecting your project. My personal suggestion would be to restore the car 100%, rebuild the engine and in a couple of years, put in a crate engine - they are easier to swap out than you think.
This is just my opinion.
Signed..your loving Dad
PS: It's garbage day tomorrow, please take the garbage to the road for me.
Old Nov 14, 2007 | 01:39 AM
FRSTR90's Avatar
FRSTR90
Originally Posted by koilmaker
Stinger12,
I'll just add that I think most small block crate engines are a waste of money and that the best engine will be one that is built by the owner..
Old Nov 14, 2007 | 02:17 AM
RunningMan373's Avatar
RunningMan373
400+ hp, $2990.00, American made.
http://www.yearone.com/serverfiles/p...26DK73488&trk=
Old Nov 14, 2007 | 02:46 AM
tfi racing's Avatar
tfi racing
If you have the original engine,just set it aside for any possible value it may have to the car in the future,there is really nothing in it you will want to reuse if you want to make some power.Get on the phone to either Davenport or Precise,both are good local builders that can deliver what you want.
Old Nov 14, 2007 | 11:01 AM
stinger12's Avatar
stinger12
Stinger12,
Lol, I knew he was going to chime in.
Old Nov 14, 2007 | 11:22 AM
PETKAH's Avatar
PETKAH
I'm putting in a 350 330hp crate motor on my 1970 - pistons "fell"
into the oil pan on original. Got it from a large Chevy dealer nearby.
For me the 330hp is plenty especially compared to the old engine.
Old Nov 14, 2007 | 12:11 PM
Glensgages's Avatar
Glensgages
http://paceperformance.com/index.asp...S&Category=132
425 HP, 449 TQ, steel-crank / roller-cam / aluminum heads, low-RPM, long-life, pump-gas motor
http://paceperformance.com/index.asp...D&ProdID=73193
Old Nov 14, 2007 | 03:22 PM
GlockGuy's Avatar
GlockGuy
BEAUTIFUL!
Old Nov 15, 2007 | 10:48 AM
lowbuck72's Avatar
lowbuck72
These days you can build stroker 383's for $2000 or less. Seems like every other issue of Car Craft they find another cheap path to small block chevy horsepower.
Old Nov 15, 2007 | 11:06 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Stinger12,
Way to go dad!!! Stinger12. Take him up on this but do a 383 with your original block, throw on a nice set of heads, bump compression and find a good shop for your machining. You can build a 450 HP motor for about the same as the crate engine but you will have gained a few things you can never get with a crate engine, The satisfaction and knowledge gained by doing it yourself. If you are careful your end result will be better, and you get to spend time with your dad doing something you both will enjoy. Here is a link to get you going. www.ryanscarpage.50megs.com/combos1.html
Old Nov 15, 2007 | 11:47 AM
stinger12's Avatar
stinger12
Has anyone bought a performance package from edelbrock? One with head, cam, intake ect...maybe I'll go that route.
Old Nov 15, 2007 | 12:22 PM
TopGunn's Avatar
TopGunn
Stinger12,
This is the best deal of all, I would never pass this up. I can't get my son interested enough to even go for a ride with me.
To Crate Engine
Old Nov 15, 2007 | 04:08 PM
djohan's Avatar
djohan
Default crate engine
In my area, I can't find a rebuilder who can come close to a crate motor...either price or warranty. I just put a long-bock in another car I own. The reason for the long block was that all the accessories came right off the old motor and onto the new one. Having to buy manifolds and brackets to outfit a new motor can be a real chunk of change, or you end up for hours in a junk yard looking for the stuff.
If you are going to go with a crate motor, make sure you price out every little item that hangs on that engine, or you will be really suprised about the final cost.
On the other hand, remember that lots of Vette people put a lot of value in "matching numbers" cars...If you plan to drive you're car for awhile and aren't sweating the matching numbers stuff...then go for it. In the case of my '72 Vette, the car is generally worth about 5K more with matching numbers than without.
Denny
Old Nov 15, 2007 | 04:21 PM
redman76's Avatar
redman76
St. Jude Donor '09
It's pretty cool when fathers and sons share interest. I wish my dad and my sons liked cars as much as I have. My boys only show interest in my vette when their girl friends come over and start drooling on it.
Old Nov 15, 2007 | 07:03 PM
Tankers's Avatar
Tankers
Originally Posted by RunningMan373
Great motor
