I own a 72 BB coupe to which I have replaced the entire interior however I have had a fit getting the grippy halves of the panel and door frame (and pillar frame) to play nice with the new half.
Both halves appear to be of the same configuration, size and location of the original plastic grip (velcro sorta stuff) but they wont lock into each other.
My question is, is their a "trick of the trade" to get the attaching stuff to play nice like mild heat or soapy water or such?
I can simply replace both halves, I understand, but I'd like to learn as I go and maybe resolve the issue using the original Chevy stuff.
From: Minnesota in the summer, Las Vegas in the winter
Am I understanding? Your panels will not match up with the curves of the door? My new panels would not match up to the door as they should have. On the passenger side the panel was close but on the driver's side I had to call in Bubba and have him put a screw in the new panel to get it to be even close to the door.
I wasn't too happy with the panel alignment but I don't know what else I could have done.
Simple fix. Lay the door panel face down on something soft (so you don't damage the vinyl). Lay a concrete cinder block on the back. Let sit for a few days. That should flex the door panel back to its proper shape. If not, put the cinder block back on and gently heat the ABS backing with a heat gun.
Common problem with repop door panels from both manufacturers.
All curves fit well to each other as do all allignments however the velcro like plastic that is intended to attach to it's "other half" on the door panel will not simply push together as intended. They do line up just fine. You just can't press them together and have them mate as intended.
I found that on the pillar post trim you have to get the trim in the exact position you want it and then give the trim a surprisingly HARD hit with the heal of your hand to set the plastic 'VELCRO' discs.
Regards,
Alan
Darn, thats a good idea! I laid mine in the sun for a few hours, but didn't use the cinder block technique. I wish I had thought of that before I used the 5/16" bolts (about six inches long) to get them to fit!
Regards,
Alan
Regards,
Alan
Regards,
Alan
Those things use a lot of force. I've had old ones pull off of the chipboard backing of original panels rather than coming apart properly...
