My Engine
Nov 16, 2007 | 12:17 AM
My Engine
My Engine! ,,, hit F11
Nov 16, 2007 | 08:03 AM
The fan is still spinning...you may need a new fan clutch.
Note: If the fan spins more than one or two full revolution after it's hot and shutoff then the clutch is probably bad.
Nov 16, 2007 | 08:17 AM
whats the extra hose on the pcv going to/(from)
Nov 16, 2007 | 08:34 AM
Quote:
Originally Posted by
pbcanney
It looks like a way to get both manifold and carb vacuum to the brake booster. The line forward of the PCV looks to go to the carb. The rearward line obviously goes to the booster, where it meets line seemingly originating back by the distributor. Maybe a direct connect to the distributor and transmission modulator line?
Nov 16, 2007 | 09:03 AM
It's going to the evap canister
Nov 16, 2007 | 09:14 AM
I don’t see a check valve inline after the vacuum filter. Maybe using it for vacuum to main vacuum reservoir?
Nov 16, 2007 | 09:24 AM
Durango_boy
Maybe the picture was taken when the motor was running? Check out the alternator pulley its moving also.
Nov 16, 2007 | 09:25 AM
bmotojoe
*Cough* It was sarcasm. *Cough*
Nov 16, 2007 | 09:27 AM
Durango_boy
Don’t cough up a hair ball on my account then!
Nov 16, 2007 | 01:07 PM
mine
Nov 16, 2007 | 01:12 PM
Nov 16, 2007 | 04:45 PM
Where did all those EPA air pumps go on those cali. vettes
Nov 16, 2007 | 05:07 PM
pbcanney
Yep, It's going to the Charcol canistor.
bmotojoe
There's a valve on the top of the Charcol canistor
hugie82
Yep,, bye bye to the air pump, first thing.
Nov 16, 2007 | 05:58 PM
hugie82
Mine came from Colorodo so it is a 49 federal smog type and not required.
Nov 16, 2007 | 06:09 PM
Nov 16, 2007 | 06:11 PM
bmotojoe
.............................. Check out the alternator pulley its moving also.
not good. Alternator clutch must be faulty as well
Nov 16, 2007 | 10:42 PM
RunningMan373
Other than the HEI cap and wires and aftermarket MC the engine bay looks very survivor quality. If the Air pump was on the car when you got it, then that confirms it even more. Any detailing in the future for under the hood?
Nov 16, 2007 | 11:18 PM
68AIR
Not as of now, just finished a Driveable/Reliable going through on it. Pulled the Air pump and pluged the holes. If you think it looks survivor now, you would of like to have seen it when I got it, 99% all original, which was part of the problem,, not very much maintenance was done. Still have all the original parts I pulled from the Car, when doing the once over though. I would say it was 99% survivor at that point,, numbers matching motor, if it matters on a '73 L48, l like that about it though.
Nov 17, 2007 | 01:09 AM
Im not much of a fan of the color green but yours looks good
Nov 17, 2007 | 01:57 AM
rayluka
Thanks, i actually like burgundy,, I think yours looks cool. Burgundy is good for a 'Vette.
