I'm starting to look at some 73-75's to get my mind off of some other stuff and get into a project. Should I consider this 75? The guy said it has been sanded down to the "fur"...
I would say he went to far if he went to the fur offer 1K if it has a motor and trans it is worth that, depends on how much fur is showing you may be able to gel coat it to save it.
If you don't mind spending $15-20k minimum for a driver worth about 12k when done have at it! That's assuming the birdcage and frame are ok and you doing all the mechanical work yourself.
Take it from someone in the restoration bussiness. WALK AWAY!!!!!
