L88 Headlights
Old Nov 24, 2007 | 08:14 PM
SargeZ06's Avatar
SargeZ06
Default L88 Headlights
I have the aluminum L88 buckets but how are lights mounted to the bucket? What light assembly is used? Any help would be greatly appreciated...
Steve
Old Nov 24, 2007 | 08:45 PM
lvrpool32's Avatar
lvrpool32
You just use the stock black cups that the lamp sits in as part of the stock headlights...the cup is simply bolted to the aluminum housing.
The clear lenses can be had from F Gregg or from Guldstrand.
Nick
Old Nov 24, 2007 | 09:10 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
Nick
I have to make a correction here. While you can bolt your lights to the aluminum housing, you will have no headlight adjustment. There is an intermediate bracket that you need(bolts on to housing, and lights bolt on to it). It is a Gm part .Guldstrand sells them as part of the set.
Old Nov 24, 2007 | 09:44 PM
SargeZ06's Avatar
SargeZ06
Okay so I think lvrpool 32 is talking about these.
Road-Race Vette do you have a pic or part number for the part you are talking about?
The OEM bulb cup uses these to adjust.
Can I just drill the same 4 hole pattern in the L88 bucket and mount them the same way as the OEM? I haven't done this so please tell me if that sounds stupid.
Old Nov 24, 2007 | 11:21 PM
0Road-Race Vette
Former Vendor
Yes, that is what he is talking about.It isnt what I am talking about. Look at the pic below and you will see that the headlights are mounted slightly higher than the buckets.They are then attached to the piece i am talking about with the clips you have posted. That way they can be adjusted like from the factory,and they wont be sunk low into the L88 bucket. I dont know the part #. You can buy those from guldstrand. I got mine from my friend Frank, who makes the headlight assemblies. If you have a hard time locating them, then contact me and I will try to get a set for you.
Stan
http://www.2ndgenrestorations.com
Old Nov 25, 2007 | 12:52 AM
international blue's Avatar
international blue
Originals used a Corvair piece I think for the mounting....
Old Nov 25, 2007 | 06:03 AM
PatsLs1vette's Avatar
PatsLs1vette
MIne also sit higher then the bucket but did the same thing as liverpool,no adjustment but they aimed perfect for my driving style at night so ileft them alone.But it is nie to know they make something that adjust for future use thanks.
Old Nov 25, 2007 | 08:09 AM
lvrpool32's Avatar
lvrpool32
I put a piece of threaded bar and two locking nuts on the bolts I used to mount the black cup and the aluminum bucket, so I can adjust my headlights if I need to.
Old Nov 25, 2007 | 08:27 AM
elctron02's Avatar
elctron02
i just drilled the bolt pattern!!!
Old Nov 25, 2007 | 09:04 AM
SargeZ06's Avatar
SargeZ06
Stan
Would that be Frank at F. C. Gregg?
Old Nov 25, 2007 | 12:13 PM
69autoXr's Avatar
69autoXr
Are your covers riveted to the body?
Old Nov 25, 2007 | 11:36 PM
0Road-Race Vette
Former Vendor
No, I actually screwed them in so I can remove them if needed.
Old Nov 25, 2007 | 11:51 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Beautiful vette!
Old Nov 26, 2007 | 09:20 AM
69autoXr's Avatar
69autoXr
I see; they kinda look like rivets in the picure.
To L88 Headlights
