Every component except for the headlight switch was bad...including the vacuum tank.
2-actuators
2-relays....rebuilt at home
1-vacuum tank....repaired at home
2-pull down switches
1-vacuum tubing kit
1-check valve
1-filter
1-spring kit for headlight mechanism
2-boxes of bandaids
It wouldnt have been to bad if it wasnt for the vacuum tank. My car has power brakes so the booster had to be removed. One of my lights is considerably slower than other so I may end up buying new relays.
From: Minnesota in the summer, Las Vegas in the winter
I did this job a few weeks ago. I enjoyed it once I got the headlight assemblies out. Also now I have a better understanding of the whole vacuum system.
Isnt that the truth. Now that mine work I have a sense of satisfaction knowing I was able to bring it back to life.
