Door Panel Mystery
Old Nov 29, 2007 | 09:29 PM
ssallen's Avatar
ssallen
Default Door Panel Mystery
I have a 1972 cpe and took off the driver side door panel and stamped on the back side of it was nov 8 1982!. I'm pretty sure 1968-82 doors were the same; but all my books show the panels being different. From 78-82 they changed a lot. I'm guessing the basic door panel is the same and only the inner skin design changed? I'm assuming someone put a 72 door skin on a 82 panel? The door panel looks original; but slightly different color(dark saddle) than dash and center console. Any thoughts?
Old Nov 29, 2007 | 09:40 PM
DZRick's Avatar
DZRick
Probably just a repo panel.
Old Nov 29, 2007 | 11:03 PM
Artsvette73's Avatar
Artsvette73
The inner door handle location changed in 78. Maybe an aftermarket panel
Old Nov 29, 2007 | 11:04 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Any other stampings?
Old Nov 29, 2007 | 11:38 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Sounds like a replacement panel. 68-77 and 78-82 panels won't even come close to interchanging.
Old Nov 29, 2007 | 11:43 PM
ssallen's Avatar
ssallen
No other stamping. My first thought was a repro also..thanks
Aggitated Monkey's Avatar
Aggitated Monkey
That is most likely the only answer.
Old Nov 29, 2007 | 11:49 PM
blitz10's Avatar
blitz10
I have new door panels for my 71 vert that I bought from a Chevy dealer 20+ years ago and they have a newer date, about 1985 on them. I have not used them yet. I believe they are ink stamped like the originals, just newer date.
Old Nov 30, 2007 | 12:01 AM
ssallen's Avatar
ssallen
That makes more sense; than a repro panel. It is ink stamped also;probably bought from a dealership for a replacement. Just noticed it also has a pc of vinyl stapled along the bottom of door under the carpet strip(deluxe door), probably hiding some damage. I'll take it to a upholstery shop and see if it can be repaired..
Old Nov 30, 2007 | 04:06 AM
curtis74's Avatar
curtis74
It's probably the manufacturing date stamped on the back of the repro panel..............
Old Nov 30, 2007 | 06:03 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That piece of vinyl is what holds the carpet strip in place.
Old Nov 30, 2007 | 07:41 PM
Alan 71's Avatar
Alan 71
Blitz10,
Just curious, what is the backing on your 20 year old panels? If it's fibreboard like the originals....you lucky dog!!!
Regards,
Alan
Old Nov 30, 2007 | 07:54 PM
Ironcross's Avatar
Ironcross
that would be the date the panel was made, not the year of application. No two years are the same. Minor details {colors, grain, and patterns} are unique to each year. Good chance it`s a Al Knoch panel.
Old Dec 1, 2007 | 01:19 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by Alan 71
Blitz10,
Regards,
Alan
Why would that be lucky? The ABS panels are lighter, stronger, and not vulnerable to moisture. You can't see the fiberboard, so it's not something that can be an original/not original appearance issue.
Old Dec 1, 2007 | 01:35 AM
vettebuyer6369's Avatar
vettebuyer6369
Lots of "service replacement parts," parts purchased over the counter at the dealer, have dates of production stamped on them and confuse people. Its not uncommon to see early design radiators, expansion tanks, etc have dates like '82, etc on them. I had a '63 SWC with an expansion tank that looked stock, and was stamped 1976, which was when a bunch of work was done and the part was bought from GM.
Thats what's going on with your door panel.
Old Dec 1, 2007 | 11:06 AM
blitz10's Avatar
blitz10
True. I have repos panels on my 67 and it took time to get them right. I am willing to bet these panels that I bought from GM and them being fiberboard will fit better and go on easier. I will have new moisture barriers in place and when finished the car will see an occasional wash only.
Old Dec 1, 2007 | 01:16 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I've heard the C2 panels are being reworked by the manufacturers because they didn't fit very well at the upper front. The C3 ABS panels are a bit notorious for being too curved, but a few days with a concrete block on the back fixes that.
Old Dec 1, 2007 | 03:36 PM
ssallen's Avatar
ssallen
The backing is fiberboard. I agree with most everybody else; that's it a over the counter dealer item replacement. The other door panel is at the body shop; so I wasn't able to check the date on it.
To Door Panel Mystery
