1970 Driver Door Question
as a complete newbie, can someone briefly outline the steps (along with tips, tricks and tools) for removing the inner door panel - and take a guess at what I will likely find? - many thanks, ed
You should get the AIM for your year, 17 bucks from Mid America. There's exploded diagrams of the entire assembly. Also catalogs from Paragon & ZIP & Ecklers have diagrams. Eckler's latest catalog has photos of the interior of both sides of the door.
Good luck.
Glenn
- other than the front and rear screws, there are no other fastenings between the inner door panel and the door itself?
- is the panel "hung" on top of the door such that once everything is loose you lift up to get it off?
- how does the window lever (manual) come off? - pried? - screwed?
- if there is a plastic vapor barrier, is it stapled? glued? - tips for removing (e.g., heating if glued) without trashing it?
thanks!! ed
thanks!! ed
The panel may need to be lifted up a bit.
The window lever also has a clip that you need remove first.
The plastic vapor barrier is held on with a caulk type material. Use a small putty knife to slowly remove.
welcome to the wonderful world of Vettes. You're going to have lots of
fun. By the way the window lever has a special tool to get the clip off-
or see one of the catalogs to see the type of clip and how you might
remove it. By the way - I've had my "70 for about 10 years and when
I first got it I almost got a license plate that said --" Honk - If Parts
Fall Off". Have fun.
my goof...my car is a 72...the AIM i have is a 70...but have assumed little changed in this area...good assumption?
- as for the lock (p.K145, K8) assume it is the clip numbered "12" that requires the special tool...such that the **** is pried off, the clip removed and then the plate ("11") is pried off? - or is the whole thing pried off as an assembly?
- on the window handle assembly (p. K142, K5) is it just 9, 10 and 11 that are on the cabin side of the door panel? - such that the housing ("8") is behind (door side) of the panel? - according to the Note with 9, item 9 fastens with 3 tabs that are bent onto the panel (the "K-3 Board") - so maybe that piece stays attached to the panel and just 10 (plate) and 11 (handle) come off? - if yes, the same tool for the lock **** is used under the plate to take the both 10 and 11 off in one go? - or do you take off the handle first (using the pry tool) and then the plate (using the same pry tool?
off on the '72 AIM because from 69-72 the cars are mostly the same.
(The 68 was the first year. The 69-70 are almost identical.) And note
to remember the AIM's were done the year previous. Don't know if
you're status but a good book with clean diagrams, how to do things,
systems explanations, etc. is "How To Restore & Modily Your Corvette
1968-82". I used it extensively.
Hopefully you have small hands. Tha access holes are pretty small.
