ebrake adjustment location?
Old Dec 5, 2007 | 03:23 PM
capecorvette's Avatar
capecorvette
Default ebrake adjustment location?
ok, adjusted the cable last night, it is at max adjustment. I was told I can adjust the ebrake pads on each side, but I cant seem to find the location of the slot to rotate the adjuster? I do see 2 elongate slots, but I can see how I would even get in there with the control arm mount so close.
Any advise? also a pic would be worth 1000 words here.
thanks
Old Dec 5, 2007 | 04:37 PM
rcread's Avatar
rcread
I'm at work, so I can't take a picture. I do have the rear wheel off, so if no one else chimes in I can take one when I get home tonight around 6 pm Pacific Time. There should be a hole in the rotor near one of the studs that aligns with a hole in the hub underneath. If your rotor isn't oriented correctly, you might have to pull it off and "re-clock" it, so that the holes are aligned so that you can get to the star adjuster (this would, of course, require removal of the caliper. You access the star wheel from outside of the rotor. The adjuster wheel is in about the 7:00 position. Shine a flashlight in the hole and you should be able to see it.
Old Dec 5, 2007 | 04:38 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
If I remember correctly you have to pull the rotor to adjust the shoes. I should remember, rebuilt mine a couple months ago. Must be getting CRS disease.
Old Dec 5, 2007 | 04:49 PM
capecorvette
i did see the hole, i will pull the wheel later, no need for pics.
thanks much
this forum is great!!
Old Dec 5, 2007 | 04:52 PM
gdm78vette's Avatar
gdm78vette
Here you go, some pictures and the how to adjust.
Old Dec 6, 2007 | 02:55 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If you have to pull the rotor, either your rotors aren't installed properly or you have front rotors on the back.
To ebrake adjustment location?
