tire shelf life?
My current rubber has enough life but who knows how short that life will become spring/summer time.
A new set is pretty cheap right now.
If I were to pick up a spare set how long with they last in storage without being mounted? They may go on the car in 2008 or not.
Is there anything you can do to the tire while its sitting to extend its shelf life like coat it with something or seal it to prevent dry rot?
Damn this season, I hate winterizing the vette.
If you do this they should remain nearly as good as new for 2 to 3 years... maybe more. Mounted and exposed to sunlight in a normal environment, they can loose a lot of their original elasticity in much less time.
One of the things I always check is the DOT number on new tires to determine how old the tires I'm being sold are. It's not unusual to have them be a year old. For race rubber, I'm looking for the newest rubber available.
Good luck... GUSTO
When it comes to determining the age of a tire, it is easy to identify when a tire was manufactured by reading its Tire Identification Code (serial number). Unlike vehicle identification numbers (VINs) and the serial numbers used on many other consumer goods (which identify one specific item), Tire Identification Codes are really batch codes that identify which week and year the tire was produced.
The U.S. Department of Transportation (DOT) National Highway Traffic Safety Administration (NHTSA) requires that Tire Identification Code be a combination of eleven or twelve letters and numbers that identify the manufacturing location, tire size, manufacturer's code, and week and year the tire was manufactured.
Today, the week and year the tire was manufactured is contained in the last four digits of the serial number, with the 2 digits used to identify the week a tire was manufactured immediately preceding the 2 digits used to identify the year.
Examples of tires manufactured since 2000 with this Tire Identification Code format:
XXXXXXXX 0600
XXXXXXXX 0600 06 - Manufactured during the 06th week of the year
XXXXXXXX 0600 00 - Manufactured during 2000
And
XXXXXXXX 0604
XXXXXXXX 0604 04 - Manufactured during 2004
The Tire Identification Code for tires produced prior to 2000 was based on the assumption that no tire would be in service for ten years. They were required to provided the same information, with the week and year the tire was built contained in the last three digits. The 2 digits used to identify the week a tire was manufactured immediately preceded a single digit used to identify the year.
For example, if the Tire Identification Code on a tire reads:
XXXXXXXX 0680
XXXXXXXX 0680 8 - Manufactured during the 8th year of the decade
While the previous serial number format identified that a tire was built in the 8th year of a decade, there was no universal identifier that confirmed which decade (tires produced in the 1990s may have a small triangle following the Tire Identification Code to identify the decade). The Tire Identification Code format used since 2000 accurately confirms the year.
And finally, hold on to your sales receipts. Most tire manufacturer's warranties cover their tires for four years from the date of purchase, or five years from the week the tires were manufactured. So if you purchase new tires that were manufactured exactly two years ago they will be covered for a total of six years (four years from the date of purchase) as long as you have your receipt. If you lose your receipt, your tires' warranty coverage will end five years from week the tire was produced (resulting in the tire manufacturer's warranty coverage ending only three years from the date of purchase in this example).
GUSTO
Tires don't like UV rays, and silicone based "protectants" only serve to reduce the ability of the tire's carbon-black content to resist UV. Avoiding both will put you ahead in the dry-rot game.
not that im disputing, the variety of compounds they use now has increased grip and shortened lifespan
ive however yet to run into a problem running pretty damn old tires, other then they dont grip as good.. tons of people running new tires are having them fly off the wheels in multiple peices for no particular reason
grain of salt
grain of salt
