1980 Questions
Old Dec 18, 2007 | 06:37 PM
Wizziamrr's Avatar
Wizziamrr
Default 1980 Questions
Purchased an "80" coupe which needs TLC. My manual tells me to drill out the rivets holding on the rotors. What size is the rivet shaft and what is used to hold the rotor in place when its put back onto the car.
Also were the original calipers SS sleeved? Has any-one rebuilt the calipers using the Ecklers re-build kit?
This is my winter project and I'm sure to have other questions as I proceed. Any advise is greatly appreciated.
Old Dec 18, 2007 | 06:50 PM
Kent1999's Avatar
Kent1999
you might have better luck posting this question in the C3 section... this section is for Corvette model years 2005-2008.
Cheers!
Kent
Old Dec 18, 2007 | 06:52 PM
ATC399's Avatar
ATC399
http://forums.corvetteforum.com/forumdisplay.php?f=3
Good luck on your project
Old Dec 18, 2007 | 06:53 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Good luck with it!
Old Dec 18, 2007 | 06:56 PM
VET4LES's Avatar
VET4LES
I'm sure by now the rivets have already been removed. I'm sure the calipers are SS sleeved also but you won't know until their removed. Eklers has good stuff. I've used them for years. Good luck and you will find lots of good information in the C3 section.
Old Dec 18, 2007 | 08:04 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Good luck!
Old Dec 19, 2007 | 06:54 PM
Wizziamrr's Avatar
Wizziamrr
Thanks everyone, I thought this was the C3 section. Still learning to navigate this site.
Old Dec 19, 2007 | 07:03 PM
rjr2007's Avatar
rjr2007
Old Dec 19, 2007 | 08:12 PM
jschindler's Avatar
jschindler
Drill them puppies out. I figure a 1/4" bit should work, but why not do it right and use a 1/2" bit. If a little is good, more is better, right? Then I'd use a #2 pencil to hold it in place when you put it back in.
The originals were not SS sleeved - they used the sleeves of a vest. Haven't used the Ecklers kit so I can't comment on that.
Okay, now you know that some of us (okay, ME) have a stupid sense of humor. I know nothing about this project, but thought you might like a little humor from your brief visit to the "C6" section. Come back and visit when you have more time
Old Dec 19, 2007 | 09:07 PM
Mike Ward's Avatar
Mike Ward
Why do you feel the need to remove your rotors? Normally they last at least 100- 125K miles.
Your original calipers were not SS sleeved.
Old Dec 19, 2007 | 10:26 PM
Wizziamrr's Avatar
Wizziamrr
Wow! Good thing I hadn't had a few beer's and decided to follow the first post I came to.
I like your sense humor and will remember to take advise with a lemon Tequila and a grain or two of salt.
Old Dec 20, 2007 | 03:28 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
It's been four years since I did mine, but I want to say that they are 5/16".
To 1980 Questions
