anti-theft question
Old Dec 19, 2007 | 06:37 AM
BassCat's Avatar
BassCat
Default anti-theft question
I was wondering if anyone could tell me a quick and easy way to disable my 77 Vette if I had to leave it in a motel parking lot overnight. I can lock the doors, and the original burglar alarm does work, however, my car can be started with or WITHOUT a key in the ignition. I thought about disconnecting the battery, but that is kind of a PITA. Does anyone know of a quick and simple trick under the hood that would disable the car from a would be thief??? Thanks in advance.
Kenny
Old Dec 19, 2007 | 06:51 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Fix the ignition?
Or you can always install a battery cut off switch and hide that somewhere.
Old Dec 19, 2007 | 07:25 AM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
The previous owner of my car installed an ingnition kill switch under the dash. It cuts the power to the coil and the car won't start.
Old Dec 19, 2007 | 07:44 AM
markdtn's Avatar
markdtn
First of all, fix the ignition. No key is probably OK for your '77 Catalina beater, but not for the 'Vette.
There are many ways to do this. If you had an old-style coil you could just take the coil wire and/or the rotor in the distributor. You could interrupt the purple wire to the starter and/or the red wire to the distributor (start and power). If you have slotted wheels you could run a cable through both front wheels and lock it making it very hard to drive off.
Old Dec 19, 2007 | 07:49 AM
mr nasty's Avatar
mr nasty
I had a 76 once that I could not lock the doors on and put an inline fuse into the nuetral safety switch on the shifter and the fuse was tucked under the side of the console. I would just pull the fuse out when I got out, until I got the locks fixed.
greg
Old Dec 19, 2007 | 01:26 PM
7T1vette's Avatar
7T1vette
If you are traveling to an out-of-town car show and lots of other cars will be there overnight, see if you can take up a "collection" from other car owners and hire a rent-a-cop for overnight surveillance. Personally, I wouldn't leave mine out overnight in an unprotected/unsecured area.
Old Dec 19, 2007 | 01:34 PM
Erics Quick71's Avatar
Erics Quick71
There was a post on this - do a search.
Many suggestions.
INcluding certain kill switches that needed to be in place before the car would start.
Example.
You need your hi beams on and door open to start the car.
Something like that.
Disconnecting the battery would be the simplest in my opinion, BUT I would go further than that anyway...
Do a search.
Old Dec 19, 2007 | 03:03 PM
Erik016's Avatar
Erik016
I had a 70 nova and the door lock was broken . I bought an automotive switch from kragens and installed it so that it cut off the coil like was said above. Then I hid it in the glove box.
Old Dec 19, 2007 | 03:38 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
If you dont have all the chrome shrouding around your Distributer You could un -hook the connector to the firing system.It should just un click. Cause any good vette THEIF knows where the batt is and could hook the Batt back up in seconds.
Old Dec 19, 2007 | 04:01 PM
7T1vette's Avatar
7T1vette
You might be able to prevent your car from being stolen....can you protect it from being vandalized?
Old Dec 19, 2007 | 04:09 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
You can disconnect the starter wiring harness from the main harness. One pull and its done. You dont have to lay on the ground or anything, just pull it loose and barely tuck it back in so it looks like its connected, that way anyone who gets under the hood wont even notice. in the morning give it a shove back in and off you go.
To anti-theft question
