Anyone seen one like this?
Old Dec 19, 2007 | 11:12 AM
Durango_Boy's Avatar
Durango_Boy
Default Anyone seen one like this?
This is a #2 rod bearing. I have never seen one look this bad. Anyone seen carnage like this without it actually damaging the rod cap?
This blew my mind. It was almost one piece.
Old Dec 19, 2007 | 11:26 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Looks like #1 rod bearing on my old 406 after my first full nitrous run...
Old Dec 19, 2007 | 11:51 AM
rayluka's Avatar
rayluka
That didnt tear up the journal? What about the cap?
Old Dec 19, 2007 | 11:53 AM
myk7's Avatar
myk7
Wow.. your journal is not toast?
Old Dec 19, 2007 | 11:57 AM
Durango_Boy
Cap is fine too.
No. I have not taken it to the machine shop but it looks like it'll clean up just fine at -.030.
It will clean up at -.030 as per machinist.
Old Dec 19, 2007 | 12:45 PM
SIXFOOTER's Avatar
SIXFOOTER
Damn, Only one I ever saw that bad had a busted crank
Old Dec 19, 2007 | 01:06 PM
7T1vette's Avatar
7T1vette
I doubt that the crank journal that bearing came from is "OK". It may not be scored or distressed LOOKING...but the heat that came from that bearing surely did so tempering to the heat treatment on the surface of the journal. If there was any discoloration of the journal at all, I'd carefully consider whether I wanted to use it again [or not]. P.S. You don't want to check hardness on a finished journal, as the indent mark made will become a stress riser and could eventually propagate a crack.
Old Dec 19, 2007 | 01:11 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Originally Posted by Durango_boy
Cap is fine too.
A .030 under crank journal? no thanks.....
Old Dec 19, 2007 | 01:49 PM
FB007's Avatar
FB007
Cap is fine too.
So, the cap is fine and the journal is fine and it will clean up at .030".
Old Dec 19, 2007 | 02:42 PM
Artsvette73's Avatar
Artsvette73
Get another crank
Old Dec 19, 2007 | 03:24 PM
Durango_Boy
Both myself and the machine shop checked everything out. The block and the caps and rods were all checked and checked out okay. They only damage was to the bearings and crank journals.
I emailed the customer with pics and recommendations from the machine shop and he decided he didn't want a -.030 crank so I bought a -.010 crank. I discussed the level of turnings with the guys there, and they said that .030 is the most they will do but that it's just as safe as a .010 so long as it's not a high RPM racing motor.
Old Dec 19, 2007 | 03:57 PM
7T1vette's Avatar
7T1vette
Heat treatment depths on crank journals are in the .015-.020 inch range (only hard at the surface for wear resistance; core hardness is much lower for toughness). If they go deeper than that, you run the risk of having a "brittle" crank. Grinding .005 off the journal would be better [if it cleaned up OK]....010 would be the max, IMHO. If you do regrind the journals, make sure the fillet radii at the edges of all journals are smooth and blended. They are a great place for cracks to start if you don't. Good luck.
Old Dec 19, 2007 | 04:17 PM
Aggitated Monkey's Avatar
Aggitated Monkey
DB,
Chuck that crank and go with a new one. May look good afther machining, however I would take the concern of hardness serious.
Old Dec 19, 2007 | 04:21 PM
Durango_Boy
Originally Posted by FatCat Blue 80
DB,
See above...after taking what I knew back to the customer, he decided the extra money for the -.010 crank was what he wanted over the -.030.
Old Dec 19, 2007 | 06:20 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Old Dec 19, 2007 | 09:19 PM
FB007's Avatar
FB007
Originally Posted by pewter99
I'm new here. What does this signify?
Old Dec 19, 2007 | 09:23 PM
wacked's Avatar
wacked
From: If the world didnt suck, we would all fall off. Troy,Ohio.
Cruise-In VI Veteran
St. Jude Donor '04-'05-'06-'07-'08
Pic of crank
To Anyone seen one like this?
Old Dec 19, 2007 | 09:25 PM
Durango_Boy
I think it means the thread has eyes on it so people misbehaving will not go unnoticed.
Originally Posted by wacked
Pic of crank
Sorry buddy, I didn't get a pic of the crank. It's at the machine shop as a core right now.
Old Dec 19, 2007 | 10:36 PM
FB007's Avatar
FB007
Now I am totally lost. Is there some probation here? There seems to be alot of wierd comments here I just do not understand yet.
Old Dec 19, 2007 | 10:51 PM
Jclgodale3's Avatar
Jclgodale3
You just have to be careful what and who you challenge here:You'll be fine.
