ready to fix tach
Old Dec 24, 2007 | 08:25 AM
cruise83's Avatar
cruise83
Default ready to fix tach
my 79 tach has been stuck at 2000. what is the best methodolgy to troubleshoot the issue? replace tach circut board?
Old Dec 24, 2007 | 08:48 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
We who are mechanically challenged would probably pick up a used one from a salvage yard or ebay.
Old Dec 24, 2007 | 09:30 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
First check and see if there is a tach filter between the distributer and it. Should be under the hood plugged into the distributer. will look sort of like an old points condenser. If there is one, I would try bypassing it first before I did the tach board.
Old Dec 24, 2007 | 09:39 AM
cruise83's Avatar
cruise83
got that, will let you know. There is an open plug hanging (yellow wire)under the "tach/bat" coil, is that for diagnostics? or can I bypass there?
Old Dec 24, 2007 | 01:01 PM
cruise83's Avatar
cruise83
ok, figured that out, bypassed the filter, and nothing doing. any other moves before I order the circuit board?
Old Dec 24, 2007 | 04:31 PM
C3 4ME's Avatar
C3 4ME
Contact board member ACECO. He fixed the circuit board on my tach in my 79. Mine read too high, and his fix was cheaper than a new circuit board. He's very honest and great to deal with.
Old Dec 25, 2007 | 12:40 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
I've chatted privately with a few forum members in the past about our circuit boards. The tach works great after the new part, except under heavy acceleration, the needle goes to zero like it's dead. Let off the go pedal and normal services resume.
Either way, getting the circuit board out is easy. Changing it is even easier.
Old Dec 25, 2007 | 09:19 AM
cruise83's Avatar
cruise83
thanks for the advise! I took apart my speed/tach lens, unscrewed the tach face and it looked like a fire was present...black residue on the green plastic...did not know the circuit board could flame.
where is the best place to get a board quickly...my son wants the vette back to drive!!
Old Dec 25, 2007 | 08:53 PM
65GGvert's Avatar
65GGvert
I've got a brand new tach board precalibrated for a 78/79. Never been installed. PM me if you're interested, I'll sell it for $65 plus shipping. I'm taking a $10 loss, but I found the problem with my tach before I changed the board. If your tach is stuck on 2k even with the switch off, you may have other problems, it should go to zero when you turn on the switch if you have 12 volts going to it. Maybe the 12 volt line is what burned? Anyway, let me know if you need the board I have. Good luck.
To ready to fix tach
