73 Electrical Problem - Not mine, helping a buddy
Old Dec 24, 2007 | 10:46 AM
62Jeff's Avatar
62Jeff
Default 73 Electrical Problem - Not mine, helping a buddy
Howdy,
I normally spend my time on the C1/C2 forum, but an acquaintance from the Jaguar forum has a problem with his 73 and he's not yet a member of this fine forum.
So, here's his question which I'm posting on his behalf:
"I have a C-3 Vette, 1973, don't drive it much, just take it to shows occasionally. Went to drive it today, battery was weak, put a charger on it with engine assist and it started. I let the engine turn off without meaning to and now it is totally dead!
Put another battery in it, same thing.
Is there a fusible link that could have blown? Seems like this happened to me years ago. I've got something in my hand that is a 3-prong relay(?) that was on the passenger side, close to the firewall. It says thermal on it. Seems like this was it. Anyway to test it with a meter? Gotta get it back in the garage!!! Jim"
Thank you all in advance for your replies.
Jeff
Old Dec 24, 2007 | 10:58 AM
LYLE's Avatar
LYLE
Originally Posted by 62Jeff
Howdy,
Jeff
I think what you took off is for the Air Conditioning. Their is a wire and the fuseable link in the wire near the starter and that could have burned out. This link is a wire between two larger connectors.
Old Dec 24, 2007 | 11:22 AM
62Jeff's Avatar
62Jeff
My buddy followed up with this:
"After screwing around with everything I could think of, and I seriously doubt if this had anything to do with it, I tapped the starter with a hammer.
Started right up. I got it in the garage, turned it off and it is dead again. At least I got it in the garage."
Old Dec 24, 2007 | 11:44 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Off topic, but Weiner dogs are really cool.
Old Dec 24, 2007 | 12:12 PM
66roadster427's Avatar
66roadster427
had the same problem on a 76 about a month ago - turned out to be the ground cable where it attaches to the frame, all the wire strands had corroded inside the cable and when i yanked on it it just completely broke off.
hope this helps.
Old Dec 24, 2007 | 12:16 PM
62Jeff's Avatar
62Jeff
Thank you all for your help thus far. I've directed my buddy to this thread and he's reading your posts.
And yes - wiener dogs rock as pets, and make great sources of innuendo-based humor (I go home every night and stroke my big wiener.........dogs)
Jeff
Old Dec 26, 2007 | 02:23 AM
ffas23's Avatar
ffas23
Being you have to hit the starter with a hammer to get the car started I would have to guess that you either have a bad solenoid or a dead spot in the starter. This happens with starters over time from wear and tear but I have also seen it happen to cars that sit for a long period of time outside in the elements. Sometimes it could also be that the positive cable is loose at the solenoid. If it is don't over tighten it or you will crack the solenoid and have to buy another. Check for a loose ground cable also but the hitting with a hammer thing is the giveaway here I would have to say.
When I read the first post of this thread I was ready to recommend that you go out and get a Milton #1260 type of battery tester w/load tester. I usually recommend this tool to everyone working on their own car. Saves a lot of headaches when determining whether the problem is a bad battery or the charging system. Its a tool a mechanic shouldn't be without. Mine has paid for itself hundreds of times over the many years that I have had it. Not very expensive either to own.
Old Dec 26, 2007 | 04:39 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
My guess is that there are two problems here - a bad starter and bad battery cables (or a lousy connection). Quite a few C3s had battery cables made of copper-plated aluminum wire (and the cheap parts-store cables are often still made this way). They corrode internally after a number of years.
To 73 Electrical Problem - Not mine, helping a buddy
