Simple tire question.....Advice?
Old Jan 1, 2008 | 11:16 AM
79SharkMan's Avatar
79SharkMan
Default Simple tire question.....Advice?
This may seem like a silly question about tire-care, but here it goes anyway
Do "modern" tires (not the old poly-bias type) become damaged or more prone to leaking more after sitting for a long period of time? My tires seem to be losing what I think is too much air just from sitting a month or two between drives...Just wondering if this is causing any real damage...If so, should I maybe do something such as putting the car up on stands, remove tires, etc....Feedback appreciated.
Old Jan 1, 2008 | 11:23 AM
moosie982's Avatar
moosie982
Is this on all 4 tires ? First thing I'd do is eliminate the possibility of a puncture or a defective valve, is there any obvious cracks in the tire(s).
Good luck,, Happy New Year. Peace,,,Moosie
PETKAH's Avatar
PETKAH
I can't give you the technical but remember when the temperature
outside changes you can loose air in your tires. Happens all the time.
How old are your tires? - if older than 5 years that could be part of
the problem.
Old Jan 1, 2008 | 11:25 AM
Merlinhaggard's Avatar
Merlinhaggard
Do you know if the tires had any beans prior to the loss?.
Sorry.
Old Jan 1, 2008 | 12:13 PM
79SharkMan's Avatar
79SharkMan
Sorry.
No worries! It's a good comment!
Last edited by 79SharkMan; Jan 1, 2008 at 12:13 PM. Reason: Additional response warranted
Old Jan 1, 2008 | 12:23 PM
79SharkMan's Avatar
79SharkMan
One tire in particular is worse than the others, so it's probably a minor valve problem or very slow leak, but they all seem to not hold air as well as I think they should....Guess I'll have to take a closer look
Old Jan 1, 2008 | 12:25 PM
79SharkMan's Avatar
79SharkMan
the problem.
Not sure how old they are...They appear to be pretty new, but they came with the car when I bought them, and I never asked the previous owner...May try to get new ones anyway in the next year or so.
Old Jan 1, 2008 | 06:19 PM
Merlinhaggard
I know drag cars tires change pretty drastically with temp change but thats at low low pressurre. I would have to thing its seals or stem. or a small nail. But all 4??
Old Jan 1, 2008 | 06:45 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Veteran: Coast Guard
Senior Member
Cruise-In V Veteran
As the temperature decreases, so does the air pressure. That is why you check tire pressures at cold before you drive. Just driving makes the temps and therefore the air pressures rise. Check your pressures at least once a month, and anytime the temp drops a lot.
Old Jan 1, 2008 | 07:57 PM
Roughrider's Avatar
Roughrider
There are a couple of possibilities...a bad valve stem, a small puncture in a tire, the bead may not be sealing properly. Another possibility is if you have the aluminum wheels. Cast aluminum wheels are porous and there's the possibility one wheel might be more porous than the others, allowing air to seep out.
Old Jan 1, 2008 | 08:12 PM
marines's Avatar
marines
Default Tires
If you are not driving your car but only ocassionally it may be best to inflate the tires 10 pounds over the normal pressure. This will prevent "flat spots" and keep the tire tight around the rim. It is easier to do this rather than place the car on stands. I work part-time (since I am retired) for Sears automotive and this is what we recommend...especially over the winter months if the car is not driven.
Old Jan 2, 2008 | 12:12 AM
Artsvette73's Avatar
Artsvette73
I seem to be adding air to my aluminun wheels with brand new tires. My ralley steels wheels very rare I have to add any air.
Old Jan 2, 2008 | 09:35 AM
Criste's Avatar
Criste
I've heard of steel wheels with rust losing air at the bead and have experienced a similar problem with aluminum wheels due to corrosion.
Old Jan 2, 2008 | 09:40 AM
Jims79's Avatar
Jims79
A local tire shop who I have been dealing w/over the last 25 years told me tires have a shelf life of 10 years before dry rot or cracking of the side wall. then its time to replace. another thing you have want to check is the condition of your 29 year old wheels. I had a bad aluminum rim on my 79 that looked good but the tire would go flat in two weeks parked in the garage. A simple fix to this problem is green slime. the tire must have no air in it. w/the car jacked up you remove the valve stem and insert the green slime rotate the wheel a few turns 360* coating the inside of the tire & rim. then insert stem and fill w/air. this works for minor cracks in the side wall & rim. or buy new wheels & tires. G/L
To Simple tire question.....Advice?
