Do you use your A/C?
Old Jan 2, 2008 | 03:49 AM
FRSTR90's Avatar
FRSTR90
Default Do you use your A/C?
In the summer, I always find myself taking the t-tops off, rolling the windows down, and sometimes popping the rear window out. I don't think, I've ever used my a/c in my DD. Is this normal? Or do you use your a/c?
My project car doesn't have a/c, would you install a/c or leave it out?
Old Jan 2, 2008 | 03:57 AM
Bangkok Dean's Avatar
Bangkok Dean
with average yearly temp 95* it is a must.
Old Jan 2, 2008 | 04:29 AM
panic's Avatar
panic
Originally Posted by FRSTR90
.....My project car doesn't have a/c, would you install a/c or leave it out?
Leave it out...
Old Jan 2, 2008 | 04:38 AM
panic's Avatar
panic
Dean, believe it or not i never switched the A/C on my japanese long train on tires while in Bangkok...the mix pollution+traffic microdust+aircon hits me badly every time.
I prefer to sweat
Old Jan 2, 2008 | 05:11 AM
couperdecar's Avatar
couperdecar
My present '79 never came with it. I wouldn't bother sticking it in . Too much $$$. To much bother. My previous '79 ( back in '83)
DID have AC and I did use it on long trips , but I can't recall using it much around town at all. So I guess I'd say if you were planning on
using the car for major trips - yeah maybe. If not - no.
Old Jan 2, 2008 | 08:18 AM
nutsy's Avatar
nutsy
it was a must have for me. the BBS throw off a lot of heat.
Old Jan 2, 2008 | 08:40 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I turn it on once or twice a year just to keep it lubricated and to check that it's still working.
Old Jan 2, 2008 | 09:00 AM
08Roadster's Avatar
08Roadster
I have a '75 vert and can't remember the last time I used the A/C. More fun to put the top down and enjoy the wind.
Old Jan 2, 2008 | 10:09 AM
in2fun's Avatar
in2fun
I live in Dallas Tx area and My 72 and 98 both have AC. I have never used the AC in the summer in both of them. I'm alway riding with the tops off. But I know that if my wife is in the car I would have to use the AC. But then again she dosen't ride in the vettes much.
Old Jan 2, 2008 | 10:11 AM
84rzv500r's Avatar
84rzv500r
Originally Posted by panic
Leave it out...
I don't have side windows or windshield wiper motor either...
Old Jan 2, 2008 | 10:18 AM
TexasYankee's Avatar
TexasYankee
I also live in Texas and never use my AC in the summer. If it's too hot to drive with the tops off, then I leave the old gal parked in the garage.
Old Jan 2, 2008 | 12:08 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
My heating cooling guy had A shotof the good stuff left and I worked on his Hottub so he charged up my system .Worked gteat for about A week then at a red light on Rt.23 South she ka blouied the hose shot all the new coolant right on my Exhaust made A hell of A smoke from under the hood . I pulled over saw what it was shut the hood and drove home wondering what it will cost to replace the hoses and switch to the new stuff. So Im Reduced to 2-60 Right now.
Old Jan 2, 2008 | 12:19 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I use it fairly often in the summer. With Missouri humidity, sometimes fresh air isn't enough.
Old Jan 2, 2008 | 12:23 PM
Young69Owner's Avatar
Young69Owner
What's A/C?
Old Jan 2, 2008 | 12:30 PM
kansas123's Avatar
kansas123
I will use mine if it works next summer; only just replaced the thermal heat limit fuse and that is what was keeping my system from working. we will see what else this spring; I want to see if I can get my gas mileage down to 5. LOL
Old Jan 2, 2008 | 12:43 PM
stock76's Avatar
stock76
Mine is still all there but the compressor went bad about four yrs ago so I just removed the belt. Maybe I'll get it working again someday.....
Old Jan 2, 2008 | 12:54 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
It's hot in the south, you bet I use it
Most of the old C3's the ac is not worth a crap for our heat
To Do you use your A/C?
Old Jan 2, 2008 | 01:25 PM
SuprJames's Avatar
SuprJames
In Florida you have to use it sometimes. I'd never be able to take dates out in it if I didn't use the AC!!
Old Jan 2, 2008 | 01:27 PM
VeroL81's Avatar
VeroL81
Here in Central Florida, I drive with T-tops off 90% of the time. I'll run the A/C for the first 5 minutes or so just to take the edge off the heat - that's it.
I run the heat all the time - it's called 350 cubic inch motor / no carpet or insulation on the floor!
Old Jan 2, 2008 | 01:34 PM
vettehed's Avatar
vettehed
GM never meant for the A/C to be used in the Corvette...it is the most ill-designed and inadequate system probably installed in a new car. It was designed for spring time in Detroit. I have a custom 70 convertible with no working air. I bought the stuff to fix it a couple years ago and then decided that it was a waste of time and money to install it since I never ride with the top up.
