76L rear end question
Old Jan 3, 2008 | 10:04 AM
tjohn1008's Avatar
tjohn1008
Default 76L rear end question
i need to find out the rear end gearing in my 1976L vett.when i turn the tire one turn,the drive shaft [input shaft] turns one and a half turns.is this a accurate way of finding out?is there a chart on this ?any way of finding out from the vin #?thanks,tj
Old Jan 3, 2008 | 10:42 AM
Artsvette73's Avatar
Artsvette73
Jack the car up and wire brush the bottom of the diff. There should be some stamping codes there.
OA = 3.08
OD = 3.36
LR = 3.36
OB= 3.55
OC= 3.70 Barring any previous owner gear change. These are factory codes.
Old Jan 3, 2008 | 04:33 PM
Gordonm's Avatar
Gordonm
Something is not right here. The driveshaft should turn a minimum of 3 turns which would indicate a 3.08. Jack up both wheels and turn the driveshaft and count the driveshaft rev. per one turn of tire. This is the most accurate way. Make sure both wheels are off the ground. The numbers are another way if you can be sure noone has been in there and changed the gears before you.
Old Jan 3, 2008 | 05:00 PM
tjohn1008's Avatar
tjohn1008
thanks,ill try that tomorrow.yes i did only have one wheel off the ground,ill let you knoww tomorrow,tj
Old Jan 3, 2008 | 06:13 PM
Gordonm's Avatar
Gordonm
If you could turn the wheel relativly easily with one wheel still on the ground it sounds like your posi unit is smoked. Probably could use a rebuild. A new and properly rebuilt rear will take a LOT of effort to turn only one wheel.
Also make sure the trailing arms are not hanging down. The ujoints will bind up making it almsot impossible to turn the wheels. Support the trailing arms somehow.
Old Jan 3, 2008 | 07:37 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
OA = 3.08
OD = 3.36
LR = 3.36
OB= 3.55
Quick and easy way to check.
Old Jan 3, 2008 | 08:06 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
OA = 3.08
OD = 3.36
LR = 3.36
OB= 3.55
found mine the other night. Bottom of the diff side, not the cover, handstamped so you may have to look close.
Old Jan 3, 2008 | 10:18 PM
hicswa's Avatar
hicswa
Put a 5/8 socket under the trailing arms and the frame to set the wheels at ride height before you spin them. Also, if you can get the cover off, count the ring gear teeth and then divide with the number of pinion teeth to get the Raito. But, in most cases the code on the case will tell you what's in there. See above for the codes.
Danny
Old Jan 6, 2008 | 02:16 PM
tjohn1008's Avatar
tjohn1008
OA = 3.08
OD = 3.36
LR = 3.36
OB= 3.55
the housing was rusted real bad befor i sand blasted it and painted.there is nos there but cannot make them out
Old Jan 6, 2008 | 02:21 PM
tjohn1008's Avatar
tjohn1008
yes,when both wheels are off the ground the drive shaft turns just over 3 turns.but as i am turning the input shaft,sometimes the left wheel will stop turning for a second and then turn again.dont kow what to do tj
Old Jan 6, 2008 | 02:27 PM
wfo76's Avatar
wfo76
Your positraction unit is shot or somebody swapped in a 68-69 open diff.
An open differential will operate exactly like you describe with the driveshaft spinning about only half the ratio.
Old Jan 6, 2008 | 06:22 PM
tjohn1008's Avatar
tjohn1008
i had the rear end apart last summer and replaced brgs and seals,did not have posi apart.snap rings were broke.what is the purpose of the snap rings? did a piece get in the posi?thanks for everbodys help,tj
Old Jan 7, 2008 | 07:49 AM
GTR1999's Avatar
GTR1999
The snap rings hold the side yokes(axles) in place. If you replaced the brg's and seals then I hope you checked the pattern as it may have changed once you removed the case.
Rings can end up in the spiders and gears and that could lock them up and break the diff.
Old Jan 7, 2008 | 08:42 AM
tjohn1008's Avatar
tjohn1008
i just replaced the carier brgs and output seals.what pattern are you talking about,the pinion to ring gear?it sounds like from what every body is saying,there is something wrong in the carrier somewhere.i am going to remove it today and dissasemble and inspect.thanks,tj
Old Jan 7, 2008 | 04:43 PM
tjohn1008's Avatar
tjohn1008
removed diff today and disasembled,found nothingbroke.the rear end had straight 80w90 gear lube in it with no additive,would this make the posi slip easy?the springs in the posi are greenish color,are these the right springs?im thinking on buying a good disc set . any good ones out there?thankstj trying to get this picture thing to work. s269.photobucket.com
Old Jan 7, 2008 | 06:53 PM
tjohn1008's Avatar
tjohn1008
removed the spring anleveled the trailing arms.seems to be ok.i still think it slips to easy.i got it apart now so i will probably rebuild the posi anyway.thanks
Old Jan 7, 2008 | 07:29 PM
GTR1999's Avatar
GTR1999
That is a stone stock posi with those nasty snowflake clutches. You have it out polish and tune it now.
PM Sent
To 76L rear end question
