Window Regulator Install???
Old Jan 3, 2008 | 01:12 PM
hugie82's Avatar
hugie82
Default Window Regulator Install???
Hi all, I replaced the gear on my window regulator and I'm not sure if I should use a nut & bolt or pick up some rivets for a stock look. What do you guys think? THANKS
Old Jan 3, 2008 | 02:16 PM
IrishJoker's Avatar
IrishJoker
Concidering where it is located and how hard it is to see .... only you will know how you attached the gear. I ended up replacing the whole regulator on the passenger side with a new on.
Old Jan 3, 2008 | 02:23 PM
Artsvette73's Avatar
Artsvette73
I have bolted later regulators into earlier doors. I put the bolt in from the inside and the nut on the outside.
Old Jan 3, 2008 | 03:00 PM
hugie82's Avatar
hugie82
Art did you have any problem with installing the door panel with the nut sticking out farther than a rivet? Thanks for your input!
To Window Regulator Install???
