BBC Valve Cover Identification
Old Jan 3, 2008 | 08:11 PM
CCrane65's Avatar
CCrane65
Default BBC Valve Cover Identification
Anyone know what these valve covers came on?
The passenger side looks identical to a Corvette valve cover but the driver side has a couple of brackets spot welded to it that I've never seen on any Corvette before.
They also do not have drippers on the underside.
cc
Old Jan 4, 2008 | 08:35 AM
CCrane65's Avatar
CCrane65
ttt
Anyone?
Old Jan 4, 2008 | 08:45 AM
international blue's Avatar
international blue
THey are simply big block gen 2 valve covers. They were probably used in some car or truck application 1970's to 1980's. The location of the spark plug wire grommet is at a later position so probably post 72. Just guessing the middle breather location on the one is "80"s to me. They are not Corvette covers because there is no power brake relief on the driver side. They will fit a Corvette non power brake car, but will not look right.
Repros are avail in chrome (correct for C-3) for about 30 bucks.
Old Jan 4, 2008 | 09:37 AM
CCrane65's Avatar
CCrane65
I think the guy I got them from didn't know the center hole was for the oil cap. I moved the grommet to the other valve cover for the PCV valve.
The plug wire retainers are all correct for my 72, just the brackets on the driver side are odd. There is one on the intake manifold side by the PCV hole and one on the exhaust manifold side on the bolt flange.
I do have a set of the chrome ones but they are not right for my 72. They just look nice.
Old Jan 4, 2008 | 12:25 PM
FRSTR90's Avatar
FRSTR90
The power brake relief was only for the C-2 cars. The '68's also came with the power brake relief and didn't need them. I've seen numerous people run the tall vavle covers and power brakes with no problems.
I think the covers are atleast post '75. I don't recall the 75' 454 having the wire looms at the bottom
Old Jan 4, 2008 | 12:37 PM
CCrane65's Avatar
CCrane65
The 72 definitely has them and I think 73 and 74 do too. 1970-71 do not but then again they got chrome!
I can tell that I do not need the brake relief with the covers I have now. No where near the power booster. There was no mention of a relief area in the restoration giudes.
Old Jan 4, 2008 | 12:48 PM
FRSTR90's Avatar
FRSTR90
I think it read some where in one of those corvette books ( its been a while) and they mentioned it was for C2's and GM used their left over vavle covers for the '68.
Didn't the '71s come standard with the painted covers. I thought it was an option to get chrome.
BTW - are you going to add the painted screw on cap? That is what hole in the middle is for correct? Atleast, for my '75 C20 it is.
Old Jan 4, 2008 | 03:11 PM
CCrane65's Avatar
CCrane65
Yeah, chrome was an option for 71. No option for 72.
I haven't decided on the painted oil cap. I didn't know it was screw on, I thought it was rubber press on. Really don't have a lot of choice, either leave it black or paint it orange. Chrome would look goofy.
cc
Old Jan 4, 2008 | 10:07 PM
iveym5's Avatar
iveym5
All 70s and 71s up to s/n 4000 got the chrome valve covers. After that only painted were used, and chrome wasn't an option.
Can anyone provide a link to $30 repro correct chrome valve covers? I need a set and all I can find is $450 and up.
Old Jan 4, 2008 | 10:53 PM
CCrane65's Avatar
CCrane65
iveym5, I got mine from Noah Performance on Fleabay but they don't have them all the time. I think they were about $26.00. They have drippers and the power booster relief as well as the correct plug wire support brackets for pre-1972 engines.
For that price they are obviously Chinese but the chrome is tons better than the flash chrome that GM used. I know that bothers some people.
Old Jan 4, 2008 | 11:01 PM
FRSTR90's Avatar
FRSTR90
I looked on ebay.. There are several for $30 and they look stock except they don't have the drippers. I assume they are made in China as well. If you don't mind that, then go for 'em. However, you can tell they are not correct because the dripper rails were spot welded which cause little dimples on the exterior. If you do, decide to go that route make sure you get the tonawanda decal. I bet most wouldn't know the difference!
I agree about the flash chrome. It doesn't have a mirror finish at all! My dad has an original set laying around that doesn't have the relief for the corvette. It came w/ his '68 Chevelle SS 396/375
Old Jan 4, 2008 | 11:18 PM
iveym5's Avatar
iveym5
Thanks, I'll check them out. $450 from the major vendors seems pretty steep to me since they are probably made in China also! Somebody's making a lot of money...
- Spence
Old Jan 5, 2008 | 03:18 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
The '71s used both chromed and painted covers. The chrome wasnt an option, they simply just used the left over covers from the '70 production. I've read in the Corvette '71 registry that some mid '71s had the factory chrome covers. My '71 is February production and it seems it has the factory chrome covers (still not %100 sure, but it sure looks like a factory covers, and last 2 PO confirmed that).
Old Jan 5, 2008 | 04:27 PM
CCrane65's Avatar
CCrane65
So back to the original question...does anyone recognize these valve covers?
cc
To BBC Valve Cover Identification
