Stereo question
Old Jan 4, 2008 | 05:47 PM
donnd's Avatar
donnd
Default Stereo question
I have an external amp and component speakers (pair of tweeters ,pair of 6x9 speakers )Which way is best to connect another set of speakers to the amp or to the cross over of the component speaker system.TIA
Old Jan 4, 2008 | 05:55 PM
Durango_Boy's Avatar
Durango_Boy
The best way is to get another set of speakers if you want more speakers.
Where do you have the current components mounted?
What is the make and model of the amp?
What is the make and model of the component set?
Old Jan 4, 2008 | 05:59 PM
donnd's Avatar
donnd
Got the speakers my question is ,where to connect them mSorry for not beung clear.
Old Jan 4, 2008 | 06:01 PM
Durango_Boy
I know, but you can't just add speakers to an existing crossover and expect better sound. What I mean was that you would need a new set of crossovers and ideally another set of channels to run them.
With makes and models of everything you have I can look up specs and see if you CAN wire in extra speakers, or if that will do more bad than good.
Old Jan 4, 2008 | 06:22 PM
donnd's Avatar
donnd
I will look the model #'s up in the morning when I go to the shop where my car is .I know it is a fosgate amp and visiontek component speakers .Thanks for your help
Old Jan 4, 2008 | 06:24 PM
Durango_Boy
Something else to consider, is that adding more speakers doesn't always make the sound better but picking the right kind of speakers paired with the right amp will always sound great. In most cases, two speakers is more than enough...especially in a small cabin like a C3.
Old Jan 4, 2008 | 06:30 PM
Recon12thman's Avatar
Recon12thman
so DB what kinda speaker setup would you recommend for the best sound i know im fashioning a sub enclosure from the space beside the battery box but the currnet setup in my 80 is like 4x6 up front and 6x9 in the back and the deck is coming out almost ate my cd yesterday
Old Jan 4, 2008 | 06:33 PM
Durango_Boy
To be honest, from trying many different variations...is a good modern head unit, a pair of really good 6.5" coaxial speakers in the kick panels, a 4 channel amp, and a sub. Channels 1 and 2 are for the front speakers, and channels 3 and 4 are bridged for the sub.
That's all there is to having a great sounding system in the car. Adding more speakers will usually just make everything sound worse.
To Stereo question
