Could use some help PLEASE
Old Jan 6, 2008 | 01:20 PM
btchn99's Avatar
btchn99
From: "Never play games with a bitch who can play them better" NE PA
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Default Could use some help PLEASE
Ok---so my husband changed the brake booster and master cylinder on our daughters C3--had one hell of a time let me tell ya---but when he was replacing the dashboard it seems like the wiring got screwed up. When the turn signal switch is on the drivers back light is on but not blinking--nothing in the front or on the passenger side and nothing goes on when you turned on the headlight switch..So he finishes reattaching everything and now when you turn the headlight switch on all the marker lights, the head lights and the fog lights come on but no tail lights.. Can someone tell me what kind of gremlin we may be looking at? I was thinking of just getting a new dash harness and starting from there but I am not sure..Any suggestions would be greatly appreciated...
We are really starting to work on this car alot now---we are running out of time to get her done so you will probably see me asking tons of questions---some will probably seem stupid but I hope you will bear with me here..
TIA
Lori
Old Jan 6, 2008 | 01:32 PM
1FSTZ06's Avatar
1FSTZ06
If you haven't already, check the 20amp tail light fuse....oddly enough I did the same thing taking out the cluster and apparently bummed a wire before disconnecting the battery.
Old Jan 6, 2008 | 02:12 PM
btchn99's Avatar
btchn99
Thanks Rick---I'll have him check that right now
To Could use some help PLEASE
