Fuel Pump Woes!!!
Old Jan 7, 2008 | 03:01 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Default Fuel Pump Woes!!!
I pulled my 69 out of storage to "play with" over the winter. The darn thing would not start so with the help of a couple neighbors, we pushed it into the garage. Turns out the fuel pump ruptured sometime during the 30 month storage.
My problem - No one has the correct fuel pump! I have tried every local FLAPS, all the mail order houses including Rockmart & Ecklers etc. Every one of the pumps they list show the input from the gas tank pointing toward the block/motor mount area instead of torard the frame.
Anyone else have this problem? I have already purchased 2 incorrect pumps! I am not looking for a NOS NCRS or original - JUST ONE THAT WILL WORK!
Any ideas?
John
Old Jan 7, 2008 | 03:07 PM
halfmoontrail's Avatar
halfmoontrail
I'm using one like this on my '69 BB without problems.
Steve
else try Doc Rebuild
Old Jan 7, 2008 | 03:08 PM
Gordonm's Avatar
Gordonm
I just looked at my old LT1 pump. From sitting in the car the inlet nipple is pointing about 4 oclock, towards the fram and the output is threaded and it pointing at about 11 oclock. This does not help but I know this is the correct orientation. I did help a buddy recently on his Vette and had the same problem. We kept getting the wrong pump. I think he finally got the correct one but if I remember one of the sponser suppliers that had a bunch of wrong oriented pumps. They corrected the problem but it was a problem.
Old Jan 7, 2008 | 03:09 PM
Go Vette Go
Thanks Steve! Guess I should have listed that it's a 350/350. I tried a BB pump - broke off the arm is SECONDS!
Old Jan 7, 2008 | 03:12 PM
Go Vette Go
Your orientation is exactly right Gordon. I had an appointment to get the car inspected 12/18/07 HA. Can't go anywhere without the pump.
Do you remember which sponsor had the right pump?
Delco discontinued it. I have tried Carter. Airtek and Pierce. No luck.
Old Jan 7, 2008 | 03:13 PM
Vette Crazzy's Avatar
Vette Crazzy
hey john,
whats the part number off the side of the flange on your old pump?
vc
Old Jan 7, 2008 | 03:21 PM
Go Vette Go
Originally Posted by Vette Crazzy
hey john,
vc
VC - It was 407092A4. I think that is a Delco number
Old Jan 7, 2008 | 03:22 PM
Vette Crazzy
40709 is the part number.
vc
Old Jan 7, 2008 | 03:28 PM
Vette Crazzy
just found the pic of mine... inlet also points toward the block.
Old Jan 7, 2008 | 03:29 PM
Go Vette Go
40709 is the part number. i manage a carquest auto parts and we show it
vc
VC can you pull one out of the box and check the orientation of the input? It should be almost 180 oposite the threaded port that goes to the carb.
Thanks man!
Old Jan 7, 2008 | 03:33 PM
Go Vette Go
That's my problem - what you have is incorrect but its the same from all mfgs. Who changed it & why?????
Thanks for trying VC!
Old Jan 7, 2008 | 06:51 PM
68/70Vette's Avatar
68/70Vette
Go to the Holley webpage, look for mechanical fuel pumps. You'll see they make several fuel pumps that have moveable bodies that allow you to rotate the body to get correct alignment with the fuel lines.
To Fuel Pump Woes!!!
