Numbers question
Old Jan 8, 2008 | 08:19 PM
seacliffe301's Avatar
seacliffe301
Default Numbers question
Is there anything in the VIN that identifies whether a car was equipped with an automatic or manual trans in the early 70's?
Old Jan 8, 2008 | 08:39 PM
Roughrider's Avatar
Roughrider
Nope...starting in '72 the VIN had an engine code, but no C3 had a transmission code in the VIN.
Old Jan 8, 2008 | 09:41 PM
Theiskell's Avatar
Theiskell
If you have the original block in the car the number stamped on the deck will tell you whether it was mated to a stick or auto.
Old Jan 8, 2008 | 09:54 PM
Deron's Avatar
Deron
The only indication would be a removable transmission crossmember. The manuals were welded in place. Auto's were bolted in place. unless it's had a frame swap once?
To Numbers question
