overdriven 4th in Muncie
Old Jan 15, 2008 | 07:15 AM
colorado1967's Avatar
colorado1967
Default overdriven 4th in Muncie
Curious if anyone has changed gears in their Muncie to have 4th gear ratio of .87
Seems like an economical fix to get better driveability without the cost of a 5 or 6 speed conversion.
If you have done, was it worth it? What rear ratio are you using? What rpm do you see at 70 mph?
link: http://www.riversidegear.com/categor...oduct-166.html
As always, your responses greatly appreciated
Steven
Old Jan 15, 2008 | 12:21 PM
5speeds's Avatar
5speeds
The manufacturer of that gearset is Autogear Company.
See www.autogear.net
Paul
Old Jan 15, 2008 | 12:38 PM
avner's Avatar
avner
I change the rear end from 4.11 70Mph 3500rpm
to 3.36 now 70Mph 2860rpm.
I bought the 3.36 (rebuild) at Ebay for $350 two years ago.
Avner
Old Jan 15, 2008 | 01:31 PM
Young69Owner's Avatar
Young69Owner
Can you change 4th from a straight through rod to 0.87? I know you can change 3rd, but you've got to have a 1:1, right? I would recommend 0.73 or 0.67 if you are going to do all that work.
Old Jan 15, 2008 | 02:00 PM
panic's Avatar
panic
Steven
Interesting...why only the M21 and not the M22...could it have the overdrive fourth?
Old Jan 15, 2008 | 02:08 PM
henderjl's Avatar
henderjl
Fourth gear is straight through and cannot be changed. What they do is change third gear to a 0.86 overdrive, so you shift 1-2-4-3. Supposedly you can flip the lever on the side cover of the transmission upside down and retain the standard "H" pattern, though I haven't tried this. This gives a bigger than normal spread between second and the new third, which is the old fourth. 0.86 is the biggest overdrive gear that will fit in the case.
I am considering this also and am interested in hearing comments from anyone who has done it.
Old Jan 15, 2008 | 02:09 PM
colorado1967
Thanks for replies.
The final can't be lower than .87 or there would be too much gap between 3-4. There is also an issue with how big of a gear will fit in the case. They actually put the higher gear in place of where 3rd normally goes to fit then adjust the shifter to work so the pattern stays the same as original.
You can do with a 22 as well but have to replace one of the shafts for another $200.
I think I am going to do it since these guys will instal / rebuild m21 with the gears for about $800 including shipping which seems like an inexpensive medium. I have a strong 383 so I am not worried about the slightly higher 1st. They sticking with a 373 which will still allow for decent start. his would not appear to be something for the guy wanting to race though but would allow a little rubber to be burned.
Old Jan 15, 2008 | 02:12 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Hey thats better than the old 3 speeds
3 Speed Manual M13
2.42:1
1.61:1
1.00:1
From the link
1st gear 2.20:1,
2nd gear 2.37:1,
3rd is 1 to 1,
4th position becomes .87
Old Jan 15, 2008 | 03:45 PM
Red 71's Avatar
Red 71
From: Melbourne, Fla. 6 months- New Middletown, Ohio 6 months
Speed Manual M13
2.42:1
1.61:1
1.00:1
1st gear 2.20:1,
2nd gear 2.37:1,
3rd is 1 to 1,
Sweethence, did you mean 1.37:1 instead of 2.37:1 for 2nd?
Old Jan 15, 2008 | 03:55 PM
sweethence's Avatar
sweethence
Wasnt me, the 2.37 is for the modded muncie as posted in the link from colorado1967
Old Jan 15, 2008 | 06:22 PM
7T1vette's Avatar
7T1vette
With that ratio set-up, it would be much better to keep the regular 4-speed [and reasonable ratio spread] and put a different rear-end in there to get the highway rpm's you want.
Old Jan 15, 2008 | 08:42 PM
colorado1967
7T1 That is kinda what I was thinking. Would I be better off changing rear end to 355's from 373's? I don't know what the impact is on rmp's at highway speed though. Would it be the same gain of 13%?
I don't spend that much time on the highway but with 373's, 75 mph is no fun. I just can't bring myself to spend several thousand for a three or four time a year spin on the highway. Last note, there is another guy building 4 speeds with the following ratios which seem like they would be more driveable:
1st gear is, 2.199 to 1
2nd gear is, 1.506 to 1
3rd gear is, 1.000 to 1
4th gear is, 0.859 to 1
Old Jan 15, 2008 | 09:02 PM
Red 71's Avatar
Red 71
Gotcha!, looks like a misprint from Riverside gear.
Old Jan 15, 2008 | 11:25 PM
7T1vette's Avatar
7T1vette
If that 4-speed does exist, colorado1967, it would be just the ticket. With a .86 final ratio, it would be like you had a 3.20:1 rear end instead of your 3.73 [not a lot different than my 3.08 and thm400]. It runs a bit under 3000 rpm at 70mph, and is not uncomfortable there. Still not much of a "gas saver".
Old Jan 16, 2008 | 08:36 PM
68 NJConv 454's Avatar
68 NJConv 454
I would consider a substitute differential until I could save up the coin for a 6spd. But the only differentials that can handle good power aren't cheap. Then it negates the fix.
I turn 70mph @ 3500 and need to fill up the tank every 45 minutes. Not fun on the wallet, but let me tell you, stomp on the go-pedal at 70mph and the needle climbs quickly. but not as quickly as the wallet jumps out the window
Next winter I'm going to keep my eye out for a viper 6spd conversion.
Old Jan 16, 2008 | 09:13 PM
RMVette's Avatar
RMVette
I've heard the same thing.
Old Jan 17, 2008 | 05:28 PM
5speeds's Avatar
5speeds
Take the time to search and read old posts in regards to this. I've answered many questions related to this gearset.
There is no "supposively" on switching the lever upside down to achieve this. It works and has been done on OD transmissions of this sort offered by GM, Ford and Mopar for many years.
and again.... Autogear made the set. NOT RIVERSIDE! They are a reseller.
To overdriven 4th in Muncie
Old Jan 18, 2008 | 12:42 PM
henderjl's Avatar
henderjl
By "supposedly", I didn't mean that I didn't know if it would work. What I meant was that I don't know if there is room in the tunnel on a Corvette to put the linkage on that way. Have you done this on a Corvette?
Old Jan 18, 2008 | 01:01 PM
5speeds's Avatar
5speeds
Yes is has been done in a vette many times... although as mentioned before in many posts here I don't like this ratio
Paul
Old Jan 18, 2008 | 06:42 PM
colorado1967
Thanks for all of the feedback and I am not out to save any gas, just trying to get a little more comfort during the very occasional hwy spin. I don't drive enough to justify droping in a 6 or even 5 speed. I would rather save the money for a new project.
Steven
