Engine Lift Plate ????
Old Jan 15, 2008 | 03:46 PM
MakoVette's Avatar
MakoVette
Default Engine Lift Plate ????
Has anyone used an engine lift plate to pull their engine. The plate that is held on by the carb studs. Seems like alot of weight to depend on the threads in an aluminum manifold.
Old Jan 15, 2008 | 03:53 PM
76stingracer's Avatar
76stingracer
I use an adjustable tilt engine puller assembly with one chain attached to the front left head and one to the rear right head.
I agree the weight of an engine lifted on those four carb bolts seems to be way to much. Plus you can't tilt the engine. Which is a must if you want to pull the tranny with the motor. (my preferred method)
Old Jan 15, 2008 | 04:31 PM
eastltd's Avatar
eastltd
I lifted a big block and transmission using a home made plate bolted to the intake.
Here's a link to the picture
http://forums.corvetteforum.com/show....php?t=1773545
rexx78's Avatar
rexx78
I used one a few times and cringed everytime I pulled it over the fenders. I since bought the same style 76 stingracer is talking about.
Old Jan 15, 2008 | 09:31 PM
mr nasty's Avatar
mr nasty
I have used one many, many times and it works great. They have 3 different holes to put your hook into, so if you did pull the motor and tranny together, just stick it in the back hole.
greg
Old Jan 15, 2008 | 10:12 PM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Used one more times than I can count. I don't use the carb studs though. I use grade 8 bolts.
Old Jan 16, 2008 | 12:26 AM
DJordan442's Avatar
DJordan442
can you use one on a tri-carb manifold? i need to lift into the bare frame next weekend
To Engine Lift Plate ????
