correct driveshaft??
Old Jan 21, 2008 | 10:28 PM
rxnova's Avatar
rxnova
1st Gear
Default correct driveshaft??
While removing my engine/trans from my 72 I noticed the driveshaft was bolted on both ends. That's right, no slip yoke on the trans. u-bolts on the rear differential and on the trans yoke. Is this correct for a 72 small block base hp automatic car?? I think this is the source of my drive train vibration. If I drive the car about 40 miles or so I get a vibration that can be seen in the rear view mirror inside the car. Could this vibration be from no expansion room and when everything heats up the vibration starts??
thanks
rxnova
