help :-( starter
Old Jan 23, 2008 | 11:13 AM
rayluka's Avatar
rayluka
Old Jan 23, 2008 | 01:05 PM
82Vettrin's Avatar
82Vettrin
is it necessary to reset the kneuter valve after wacking the starter ?
Old Jan 23, 2008 | 01:17 PM
RagTop69's Avatar
RagTop69
Originally Posted by nutsy
i whack it all the time. start soft and slowly increase.
A lubricant like hand lotion or KY Jelly is sometimes recommended.
Old Jan 23, 2008 | 03:52 PM
Ironcross's Avatar
Ironcross
Not if you oil the muffler bearings....
Old Jan 23, 2008 | 05:25 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Back to seriousness...
Check the battery cables. Some C3 years used copper-plated aluminum cables, which are utter garbage. My 77 factory cables were this way. AC Delco makes good replacement cables in 100% copper which are available from most (if not all) Corvette vendors. Changing the long + cable is a PITA, though.
Old Jan 23, 2008 | 07:59 PM
ngroat7007's Avatar
ngroat7007
so it was the starter
batter is perfect
all it needed wasawack itseemed to hit a dead spot because it works fine now
but new problem engine turns but wont fire it sounds like its so close though
Old Jan 23, 2008 | 08:23 PM
ngroat7007's Avatar
ngroat7007
could a mod delete or lock this topic as it has ended up being the same thing as the one in tec
thanks
