Cross-Shaft, Lower Control Arm Question
Old Jan 22, 2008 | 06:20 PM
Tewski's Avatar
Tewski
Veteran: Marine Corps
St. Jude Donor '06 thru'17, '23-'26
Default Cross-Shaft, Lower Control Arm Question
Are the gooves on this cross shaft normal? I know they probably weren't machined to super tight tolerances, but this seems excessive. Any help would be appreciated. Thanks
Old Jan 22, 2008 | 06:25 PM
Durango_Boy's Avatar
Durango_Boy
Mine didn't look much better and they work fine.
Old Jan 22, 2008 | 09:21 PM
seventysixvette's Avatar
seventysixvette
Don't know if it's just rough machining or what, but mine looked 'zactly the same and works fine.
John
Old Jan 23, 2008 | 06:03 PM
tlynam's Avatar
tlynam
Your bolts were loose at some point in time and the bushing rotated on the shaft. When installed properly, the washer should compress the bushing's inner sleeve tight against the shaft so that it will not rotate.
Old Jan 23, 2008 | 07:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Looks pretty normal to me.
To Cross-Shaft, Lower Control Arm Question
