Radiator question
Old Jan 25, 2008 | 06:55 AM
BassCat's Avatar
BassCat
Default Radiator question
I know this is probably a dumb question, but does a 1977 Vette with stock 350 have a drain plug on the radiator? If so, where is it. I've looked and can't seem to locate it. Thanks,
Kenny
Old Jan 25, 2008 | 06:58 AM
noonie's Avatar
noonie
Passenger side bottom under the lower hose port.
Old Jan 25, 2008 | 08:36 AM
Durango_Boy's Avatar
Durango_Boy
That's where mine was.
Old Jan 25, 2008 | 11:34 AM
r44s's Avatar
r44s
Pulled the radiator out of my 73, with no drain plug. Not original but no plug either. The aluminum one going in does have a plug for sure. Made a mess in the garage draining the old one.
Old Jan 25, 2008 | 03:52 PM
CJ 77's Avatar
CJ 77
If I remember right it was what we used to call a petcock and you could only see it if you craweled under there.
Old Jan 25, 2008 | 10:36 PM
r44s's Avatar
r44s
As long and as hard as I looked at the bottom of the radiator there wasn't one to be seen. Having it on the bench now didn't make one appear. Can't imagine not having one, it's a first for me.
Old Jan 26, 2008 | 06:50 AM
BassCat's Avatar
BassCat
Yep, I found it. Right where you guys said it would be. Could have sworn that I looked there before. Anyway, the previous owner has rounded the bolt off, but at least I know where it's at. Thanks,
Kenny
To Radiator question
