Engine Temp Sensor w/AFR Heads (Pic)
Old Jan 26, 2008 | 09:08 AM
Emeightch's Avatar
Emeightch
Default Engine Temp Sensor w/AFR Heads (Pic)
Well, I had to beleive I would run into things like this, but do they sell sensores with a smaller thread diameter so I can fit it into these AFR's?
http://i96.photobucket.com/albums/l1...h/DSC01502.jpg
Old Jan 26, 2008 | 09:26 AM
Gordonm's Avatar
Gordonm
Yes they do. I run a small one in my AFR heads. I had to work with the parts guy to come up with a sensor that would fit and work with the gauge. I can't remember what the number is but it was a later model Vette that took the smaller sensor.
Old Jan 26, 2008 | 09:43 AM
Durango_Boy's Avatar
Durango_Boy
Get a temp sender for a 1982 Corvette.
dmaaero's Avatar
dmaaero
or...... you can pick up a brass male/female adpator at the hardware store, and use your original temp sensor.
Old Jan 26, 2008 | 10:04 AM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
That's what I had to use with my Vortec heads.
Old Jan 26, 2008 | 01:30 PM
Emeightch's Avatar
Emeightch
I guess I also find myself wondering how exactly does it work? Does it simply check the temp of the coolant and if I do use an adaptor, would it be moved too far outboard to be effective?
Old Jan 26, 2008 | 01:59 PM
Durango_Boy
You don't need an adapter. Get an '82 Corvette sending unit, which is like $15. If goes in the same head and will fit the smaller bung.
Old Jan 26, 2008 | 03:02 PM
Surfer69's Avatar
Surfer69
Or.....just use the intake manifold port at the fwd end with your stock sensor.
Old Jan 26, 2008 | 03:29 PM
C3 Stroker's Avatar
C3 Stroker
That's what I ended up doing with mine.
BTW, if you are ordering your new heads directly from AFR, let the tech know which size temp. sensor your're using and they will drill the correct size hole in the stock location for you.
Old Jan 26, 2008 | 03:30 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I just drilled and tapped my AFR heads for 1/2" NPT to use the proper sensor for my temp gauge, and my SPAL fan temp sensor also needed the same size, so I did both heads the same. Not a big deal with the heads off the car and if you know how to use a drill and tap.
Old Jan 26, 2008 | 06:03 PM
Emeightch's Avatar
Emeightch
Thanks Guys!
Old Jan 27, 2008 | 06:56 PM
Emeightch's Avatar
Emeightch
Well, I bought the '82 sensor and now the electrical connector is different. I take it that I need to get & splice in the correct one right into the new harness?
http://i96.photobucket.com/albums/l1...h/DSC01507.jpg
Always something...
Old Jan 27, 2008 | 07:24 PM
Durango_Boy
Always something...
I think that your stock terminal will still fit on just like a female spade terminal would. Give it a shot. If not, is a simple, cut, strip, crimp, and you're done.
To Engine Temp Sensor w/AFR Heads (Pic)
