Stuck Bolts
Old Feb 1, 2008 | 10:37 PM
Recon12thman's Avatar
Recon12thman
Default Stuck Bolts
im tryin to remove the LR caliper from the bracket but the bolts have the strength of gods and wont budge at all any suggestions to removing them bolts because im about to rip it off
Old Feb 1, 2008 | 10:41 PM
h2ohouse's Avatar
h2ohouse
PB blaster let it sit overnight..... put a wrench on it and beat the hell out of it....................PB blaster does usually work well.
Old Feb 1, 2008 | 10:46 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
PB blaster is some good stuff.
Then a big breaker bar.
Good Luck....
Old Feb 1, 2008 | 10:50 PM
Recon12thman
ok i know some tools but what is a PB blaster
Old Feb 1, 2008 | 11:04 PM
James.70's Avatar
James.70
From: Show me a cold beer and I will show you a happy man Maryland
Its a spray used for removing siezed bolts and other stuck stuff. You can find it at most parts stores and it works great, but be carfull what you get it on cause it doesnt like paint. I dont know what is in it but it works, I also never heard of it until I came hear and kept hearing these guys rave about it so I got it and now I always have it when wrenching on the vette. Before I found this forum I had removed my calipers like you are know and had the same problem. I ended up using my impact gun on it and that worked but it was a pain, I wish I had known about pb blaster and CF then, it would have saved ALOT of time with trial and eror and busted knuckles
Good luck!
Oh you can see the end result of the PIA suspension teardown in avatar
Old Feb 1, 2008 | 11:08 PM
Recon12thman
thanks guys looks like im goin to walmart
Old Feb 2, 2008 | 09:44 AM
Merlinhaggard's Avatar
Merlinhaggard
Butane torch at Home depot. Just a bottle with a tip on it..
Old Feb 2, 2008 | 09:48 AM
LYLE's Avatar
LYLE
Impact wrench works for me. Six point socket.
Old Feb 2, 2008 | 09:56 AM
theandies's Avatar
theandies
PB Blaster is the stuff. WD-40 is not a penetrenet, it is a lube/water displacing chemical. PB Blaster penetrates and loosens rust etc. Great stuff and you can actually see it wick into the threads of the fasterners you spray it on.
Old Feb 2, 2008 | 10:01 AM
chevy69's Avatar
chevy69
St. Jude Donor '08
PB Blaster is your friend...
Old Feb 2, 2008 | 10:42 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
PB Blaster will help, but heat is your friend.
Good Luck
Old Feb 2, 2008 | 04:38 PM
jchapla's Avatar
jchapla
PB blaster and 1/2 socket set with a 3 foot section of pipe to slide ratchet end on. I was able to remove almost every bolt on a car that's been sitting for 20 years in florida.
Old Feb 2, 2008 | 04:43 PM
75 Red Vert's Avatar
75 Red Vert
To Stuck Bolts
