I have a 69 350/350 with the stock cast iron boat anchor intake manifold. I'd much prefer a nice shiny aluminum intake but something made by GM in that era - don't want an aftermarket intake. Well, not for now, anyway.
Anyone know of a stock GM aluminum intake available in the late 60's or early 70's that will work?
GM had dual plane aluminum intakes they put on LT1 and 302's and such motors that came with Holleys in 69-70. I'm sure if you search around in hemmings or on line you could locate one. GMPP also has a current version they sell but I think they all have EGR port.
I am coming to the same conclusion about the Rochester Scott. CF was my last resort. I am going to give it a couple weeks & either stick with what I have or go to aftermarket.
Thanks for the link. Hadn't thought about the posibility of the fuel line. I may not get what I want but I sure will be well informed!!!!!
If you're happy with how your current intake is performing why not get it plated or powder coated? Given equal design, the air doesn't care if the intake is made of cast iron or aluminum. Aluminum has the advantages of lighter weight and faster heat dissipation, but no inherent advantage in performance per se.
Thank you SO much for your above comment....I've been wondering if there were enough differences between cast iron and aluminum to justify changing my old, original cast iron intake out and doing the switch...It looks like the only real advantage to alum. is weight savings, which is still a good reason.....
Thanks Roughrider!
I hadn't thought of powdercoating the original manifold. Hell, I can do that myself. Now to find a good powder supplier for the chrome/aluminum look.
You could probably use the alumium manifold from a midyear HP engine (e.g., 327/350 hp or 365 hp). These were raised slightly but allowed for a stock hood and also provide the necessary distributor nipple clearance.
Nipple clearance is also something to consider. When I put a Performer RPM on my '64, I had to reclock the distributor "1/2 tooth" over so that the vacuum port was accessable.
The real advantage will be the weight savings.
the issue on that choice would be the hole for the oil fill tube in the front of the intake. You would need to either find a way to block off the opening or leave the oil fill tube in place which would look out of place on a 350ci motor which already has the oil fill in the valve cover. not to mention that the aluminum 461 intakes from the SHP C2 motors (350hp and 365hp) are pretty pricey if you find one in good condition. i've seen them go for $500 - $600 on eBay - less if they are in a less pristine condition but still in the $200 - $300 range but than a good low pressure glass beading will bring it back looking good as long as the casting is still in good shape.
John, this wouldn't be my first choice for your motor, again because of the front oil fill tube, but if you wanted to try this route let me know as i may have someone that has one or two of the 461 intakes available.
Hi Barry! I have seen a couple pre-69 intakes but the oil fill tube is not an option. While the lower weight of the aluminim intake is nice, I don't want this to be a butcher job.
..... by '461' intake, I assume this is the last 3 digits of the part-number?
I have an older Chevy intake, that I 'believe' is a 327 CID / 365 HP piece, and I 'believe' the part number is '3844461' (it is on a car I have in-storage over 1000 miles-away and can't confirm the number, so I am going from-memory here..... ), which I bought at a swap meet in '81 for $10.
correct, the "461" intakes have the casting number of 3844461. For ease of discussion and reference they are usually referred to by the last three numbers of the casting.
These last three digit references are also commonly used on other parts also, such as heads, blocks, etc to identify them from other casting part numbers, such as a "870" block (most 327 block castings - casting number 3782870), "962" ('65 396 block - casting number 3855962), etc.
If you got a 461 intake for $10 you picked up a great deal. Of course back in '81 none of the pricing is what it is today but find another 461 intake and see what it will cost you now!!
