t-top weatherstrip question
Old Feb 4, 2008 | 08:30 PM
Georgia1974's Avatar
Georgia1974
Default t-top weatherstrip question
On my 74 on the tops there is a metal frame with 3 phillips screws that the weather strip sits in or is part of the original weatherstrip, mine was so shot that I could not tell. Does the replacement weatherstrip just go in between this metal strip. Or do you remove this piece for replacing the weatherstrip ?
Old Feb 4, 2008 | 09:42 PM
72ls5fla's Avatar
72ls5fla
Pretty sure that the new WS goes into the frame/channel.
Just be sure to clean it out with WS adhesive remover before putting the new WS in.
Corvette Rubber sells the BEST reproduction t-top WS I have seen so far. They are molded from real NOS molds ad are a darn great fit. They don't leak like the Softseal WS.
After you install the WS you may need to adjust the t-tops to seal against the pillar post WS and window correctly.
Bill
Old Feb 4, 2008 | 10:10 PM
donnd's Avatar
donnd
Bill
The ws has to be fitted into the channel.Just did mine on the weekend.
Old Feb 5, 2008 | 02:35 AM
RunningMan373's Avatar
RunningMan373
Theres a lip on the W/S that slides/is pushed into the outside curved over lip in the channel. clean it out with a scotch pad and alcohol and regoup it while installing the new stripping.
Old Feb 5, 2008 | 07:04 AM
donnd's Avatar
donnd
Possibly on the made in China type there is no lip .I used the made in the U.S.A. stuff on the weekend and had to fit it into the channel.
To t-top weatherstrip question
