Starter Heat Shield?
Old Feb 5, 2008 | 06:55 PM
RABVET427's Avatar
RABVET427
Default Starter Heat Shield?
Did the factory install starter motor heat shields on small blocks in 1970? And is this available OEM or reproduction? ---- I know they did on the big blocks but not sure about small blocks.
Thank you.
Old Feb 5, 2008 | 08:13 PM
Ironcross's Avatar
Ironcross
If they did, it only covered the switch because the bakelite cap on the end as that is the only style that was ever mounted on a GM starter. A good possibility that they were used however. And I would say they did. Ford did the same thing with the 429/460 starter as they used a similar external top mounted starter switch like GM`s.
Old Feb 5, 2008 | 09:19 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
The SB starter heat shield is much smaller than the BB shield and didn't cover as much area.
Bullshark
Old Feb 5, 2008 | 10:34 PM
gofastvette's Avatar
gofastvette
One size fits all, only the noses are different between BB and SB until the 454 where upon there the same.
To Starter Heat Shield?
