Radiator Shroud Problem
Old Feb 5, 2008 | 07:53 PM
DaJesterMan's Avatar
DaJesterMan
Default Radiator Shroud Problem
So here's the deal, I have a '77 vette which the previous owner put a 454 into. (the old engine was a 427) However, when I bought the car, it did not come with a radiator shroud (perhaps the old shroud wouldn't fit)... My question for the wise old men on this site is, what kind of shroud do I buy? Will the big block shrouds work from the older C3's or do I buy the one that fits into a '77, and try to modify it to fit the new engine? Any advice is greatly appreciated... I'm in the military and don't have a lot of money, so buying multiple shrouds isn't really an option... THANKS!!!
Old Feb 5, 2008 | 08:02 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Is 77 a typing error, 1977 never came with a 427ci, only 350 ci.
Old Feb 5, 2008 | 09:04 PM
DaJesterMan
No, this is the info I was given, which is probably wrong from what you have told me... so lets assume it was a 350... will the big block shrouds fit inside a later model C3?
To Radiator Shroud Problem
