shop air compressor
Old Feb 7, 2008 | 09:47 PM
Toms82's Avatar
Toms82
Default shop air compressor
Hi,
I don't have a huge garage, but would like to purchase an air compressor. What's the smallest HP that will run an impact wrench?
Any recommendations on brand?
Thanks,
Tom
Old Feb 7, 2008 | 10:01 PM
STINGRAY1WORD's Avatar
STINGRAY1WORD
A impact gun would not be a big deal compared to a sander or grinder where the compressor cant keep up with the volume. The more horsepower the better but its all about volume. The bigger the tank the better. I have a craftsman 25 gal works great with impact tools but sanders or a die grinder is not the best.
Old Feb 7, 2008 | 10:07 PM
Todd M's Avatar
Todd M
Not to hijack this thread, but I am also shopping for a compressor. I am interested in painting, bodywork sandblating and a beadblast cabinet. What is a reasonable size for a home hobbyist user? The sandblasting requires a lot of air.
Old Feb 7, 2008 | 10:43 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i went with a 3.2hp with a 60gal. vertical storage tank. so far i am very happy with it.
Old Feb 8, 2008 | 12:24 PM
C3 4ME's Avatar
C3 4ME
I just have a 30 gallon 5 horse. It works fine for an impact wrench and and air socket. It definitely is not enough for tools that use a lot more air like a DA or a cutoff wheel.
Old Feb 8, 2008 | 12:49 PM
CORVETTEKARL's Avatar
CORVETTEKARL
My first compressor was 2hp 20gal oil pump type. Not the best for painting. The new one is a 6hp 33 gal oil free. Much better for painting. Eliminates oil vapor so all you need to worry about is moisture. IMHO oil free is the way to go. It works fine with pneumatic tools and HVLP spray guns.
Old Feb 8, 2008 | 12:58 PM
markdtn's Avatar
markdtn
Do a search on this topic, there was a good thread within the last month. The simple answer is buy the biggest one you can afford so you can use it for everything later. Impact wrench does not use the volume of air that sandblasting does, but a 1/2" impact does use a good bit of air. I like Ingersoll Rand for both compressors and air tools. You can get the compressors at Home Depot and the tools at Northern Tool. I would not get an oilless comprerssor, and you get what you pay for in air tools. That being said, I have had a $7 Big Lots die grinder for 15 years now and it sounds like it has rocks inside, but it still works fine if you keep it oiled. It is an air hog though.
Old Feb 8, 2008 | 02:17 PM
68/70Vette's Avatar
68/70Vette
Originally Posted by markdtn
. I like Ingersoll Rand for both compressors and air tools. .
Sears sells both their own brand and Ingersoll Rand. To see the big selection they sell, pick up their tool catagol at any Sears store or maybe look at their webpage (???).
Old Feb 8, 2008 | 10:19 PM
wro87's Avatar
wro87
If you plan to do alot of work painting and body work you need to get at least a 5hp twin cylinder 2 stage compressor 220volt with at least a 80 gal tank it will give lots of CFM and pressure but be sure to use the same size lines comming out of the unit along with a good size regulator and water trap. Ours will keep up with our big blaster and it has forced air ducted fan cooling across the unit. I ordered it from MENARDS years ago and has not given us any trouble. If it wasn't so cold I would go out to see who it was made by, yea it is left out in an unheated garge all the time.
WRO87
Old Feb 9, 2008 | 12:57 AM
MN-Brent's Avatar
MN-Brent
I go tthe Husky 2HP 26 Gal upright from the Home Depot. Works good for me so far.:
Old Feb 9, 2008 | 08:10 PM
stpman's Avatar
stpman
I have a 60 Gal 3 hp and it's not enough. I'm always waiting for it to recover when I'm using my blast cabinet and my HVLP guns. looking to upgrade to a 5 hp min.
Steve
Old Feb 9, 2008 | 08:15 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I think it's mostly about the CFM. 3.5 H, 60 gallon, 13.5CFM, $450 + tax at Harbor freight.
Maybe not a big name, but when you look closely, it uses most of the same components as one. Had it two years now. It'll run any air tool all day - even painted a trailer with it.
Old Feb 9, 2008 | 08:38 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Same here.....Husky.....Home Depot. 2 cylinder / 2 stage / belt drive / nice and quiet compared to the vibrating pump / About 500 clams.
To shop air compressor
