Birdcage Question
Old Feb 9, 2008 | 09:35 PM
Kahle76's Avatar
Kahle76
Default Birdcage Question
What is the birdcage? Any photos of a rusted/problem birdcage. When I jack my car up by the rocker panel, the door gap opens up towards the top. Is this a birdcage problem? Thanks for you input.
Old Feb 9, 2008 | 09:41 PM
Erik016's Avatar
Erik016
Birdcage is the widndow/ t top support. Conecting to the firewall and rear window. Problem areas are typically at the bottem of the window near the wiper mounts
Old Feb 9, 2008 | 09:48 PM
Erik016's Avatar
Erik016
are you jacking up the actual rocker panel or the frame behind it?
Old Feb 9, 2008 | 09:51 PM
Kahle76's Avatar
Kahle76
I'm jacking on the frame toward the front of the door.
Old Feb 9, 2008 | 09:57 PM
Erik016's Avatar
Erik016
it should have some slight play when you jack the car up. I would take off the kick panel on the inside and check the door bolts for loseness. Also while your looking you should be able to see if there is rust in there.
To Birdcage Question
